02-07-2010, 20:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: NIGERIA, DELTA STATE, WARRI
Member: 53891 Status: Offline Thanks Meter: 41 | Unable to fix E71 superdongle Phone Type: RM-346 (Nokia E71) SW Version: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia Imei plain: 35420803153798-9 Product Code: 0559583 ApeCoreSw: 300.21.012 ApeVariant: 300.21.012, Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354208031537989 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia ApeCoreSw: 300.21.012 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 10.515 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-346_354208031537989_SD.RPL" missing NPC data. Certificate programmed successfully ! How can I get this fixed. Pls help?????? |
The Following User Says Thank You to kaino147 For This Useful Post: |
02-07-2010, 23:47 | #3 (permalink) |
Member: 53891 Status: Offline Thanks Meter: 41 | it keeps giving this same error after running sd repair process all the time: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia ApeCoreSw: 300.21.012 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 32.907 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-346_354208031537989_SD.RPL" missing NPC data. Certificate programmed successfully ! Pls help, what should i do next????? |
02-08-2010, 08:15 | #5 (permalink) | |
Member: 53891 Status: Offline Thanks Meter: 41 | Quote: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia ApeCoreSw: 300.21.012 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 43.000 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-346_354208031537989_SD.RPL" missing NPC data. Certificate programmed successfully ! Phone Type: RM-346 (Nokia E71) SW Version: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia Imei plain: 35420803153798-9 Product Code: 0559583 ApeCoreSw: 300.21.012 ApeVariant: 300.21.012, ApeTest: RM346ENO74110842.a36 ApeProd: )300.21.012 18-06-2009 RM-346 (c)Nokia Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SECURITY_TEST passed SIMLOCK_DATA corrupted! Pls what step do i have to take from here? | |
02-08-2010, 16:43 | #7 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | tested today just for educational purpose ... E71 3G UK with 300.21.012 ... detected like PA_SL2 PA_SL3 ... Calculate NCK do not work ( it's easy to understand why... ) ... repair SIM lock for sure going to damage SIM-Lock area and phone go to SD_key corrupted ( after back SIM-Lock backup RPL ), Super SD work fine ( and after 309 rewrite and recover CERT - phone go to initial state ... Eee... Simlock RPL is a way to unlock such types of phones ( without SD_key headaches ) ... In final -> what can I say ... IF you have NPC valid, then MX-Key will do the job in any case - do not mean what you need to make - Unlock, SD repair, Contact service repair ect ... WBR, DebeliaMark, BG |
02-09-2010, 10:19 | #8 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Nord Romania Age: 42
Member: 323481 Status: Offline Thanks Meter: 43 | Same problem for me too.... Phone Type: RM-346 (Nokia E71) SW Version: V 100.71.821.4 06-06-08 RM-346 (c) Nokia Imei plain: 35292402129746-5 Product Code: 0559571 ApeCoreSw: 100.07.76 ApeVariant: 100.07.76, Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.594 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-346_352924021297465_SIM.RPL" missing NPC data. Certificate programmed successfully ! Reading Simlock info ... SIMLOCK_DATA corrupted! What to do? I have allready downgraded from ver. 400 to 100 with this instructions http://forum.gsmhosting.com/vbb/show...5&postcount=21 Last edited by kosta25; 02-09-2010 at 10:25. |
02-09-2010, 13:33 | #11 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Complete repair damaged simlock by MXkey except SL3: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. another shortcut You got Only NPC? NO PROBLEMO! br, |
02-09-2010, 13:43 | #12 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Quote:
b.r. | |
02-09-2010, 13:55 | #13 (permalink) |
Member: 323481 Status: Offline Thanks Meter: 43 | missing NPC data. Certificate programmed successfully ! Phone Type: RM-346 (Nokia E71) SW Version: V 100.71.821.4 06-06-08 RM-346 (c) Nokia Imei plain: 35292402129746-5 Product Code: 0559571 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SECURITY_TEST passed SIMLOCK_DATA corrupted! |
02-09-2010, 14:35 | #14 (permalink) | |
b.r. | |
I need to fix E71 SD data, I began to PM Auth, always server error! ! Please check! ! | liufeifei | Universalbox | 26 | 03-02-2010 22:50 |
Unable to unlock E71 v210 why ? | jawad8305 | Cyclonebox | 7 | 01-13-2010 16:43 |
*** Ended Up Buying Customer New Gx17 As I Was Unable To Fix Start Ng *** | moni108 | Sharp | 3 | 08-05-2006 16:35 |
Unable To Fix 1100 Again | yousha | UFS2 + UFS3-Tornadoflasher | 16 | 02-16-2004 19:43 |
Unable to fix C25 with 'Wrong softw.' | Johnny | x1x to x45/x50 | 2 | 10-13-2000 16:02 |
