when i try to flash E72 new phone, [scan] is ok. but when [flash]
Library version: 1.0.0.11866, Date: 26-01-2010
Due to USB protocol limitation, certificate backup will be skipped.
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\BB5_3552390xxxxxx x_PM.rpl"
Processing file: rm530_021.024_prd.core.fpsx as MCU
[BB5,XSR 1.6] size: 96.00 MB
Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104
Battery voltage: 3986 mV
Phone type: RM-530
Product code: 0586208
SW version: 021.024
LanguagePkg version: 021.024021.024.40.01021.024.C00.01
Version from phone: 021.024
Version from file: 021.024
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 22A3D1D6
Bootstrap failed!
Flashing terminated with error(s) in 22.708 s
RX Buffer:
Nokia E72 USB Generic detached.
Device changed, found new Instance: nmwcdnsuc\Nokia USB Flashing Generic
Nokia USB Flashing Generic ready.
it just keep device found, there is no problem if flash with phoenix
Flashing started
Creating product data items list
Product data items list created
Backup not required
Started product mode change
Product mode change complete
Flashing phone
Initializing
Asic CMT: Verifying communication to device...
Getting product info...
Scanning image files...
Unable to open and parse CmtUlo file C:\Program Files\Common Files\Nokia\Tss\Flash\MICROv10_alg2nd.fg
Loading secondary boot code: 14912 bytes
Secondary boot loaded
Loading update server code: 520290 bytes
Update server loaded
Partitioning....
Partitioning complete
Erasing....
Erasing complete
Asic CMT: Start programming 171808 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Programming complete
WARNING: Asic CMT: NAND status reported bad blocks
Asic CMT: programming succeeded
Phone flashing completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Communication verified
Doing factorysets
Factorysets complete
Loading default data to phone
Getting Data Package
Reading product state
Starting backup/restore sub-procedure: data item pre-delay
data item pre-delay
data item pre-delay
Sub-procedure completed: Succeeded., result code: 0
Starting to backup/restore data item: ProductProfile, version: 1.1
Data Item backup/restore completed: Succeeded., result code: 0
Starting backup/restore sub-procedure: data item post-delay
Backup/restore result: 0 out of 1 items were not backed up
Default data loading complete
Stopping all operations, returning phone to default mode
All operations completed
Product flashing succeeded.
many bb5 i can't flash with usb, esp symbian not s40
