08-13-2012, 07:03 | #1 (permalink) |
Junior Member Join Date: Mar 2007 Location: Pl
Member: 476474 Status: Offline Thanks Meter: 0 | [HTI-BOX green] problem with booting bb5 phones Hi, I have a problem with my HTI BOX. I can not run some bb5 phones in local mode, for example: E61i and 3110c are ok, but 6300 and 6700 i can't run in local mode. I try some solution (changing bcp69 to other transistor(bc557), added capacitors) and... no result. Can anybody help me? Sorry for my english. |
08-13-2012, 08:42 | #2 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
The World's 1st & only Software Mxkey with Soft TMA Resistor. Very simple solution in your case, just shift & increase Level of Soft TMA Resistor from 0 to 1/2/or3 by Click on it will make Phone to Run in Local Mode after Buscheck. BR, ZUBER | |
08-13-2012, 09:17 | #3 (permalink) |
Member: 476474 Status: Offline Thanks Meter: 0 | i'm tring changing tma values and no result. Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! |
08-13-2012, 10:07 | #4 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Check or change USB Port, if using Hub then remove & connect to direct USB, Check or Change Box USB Cable. If everything OK, then at the last change Transistor BCP69 in Image with same 1. BR, ZUBER |
08-13-2012, 10:48 | #6 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
- try different cables. - if your NORMAL phones CANT go to local mode while doing buscheck, try to set SoftTMA Resistor to 15K, then do buscheck again. i usually do that n 90% works (never say 100% or 10000% even it is sure one) br | |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
