03-11-2013, 09:47 | #1 (permalink) |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | Unlock Nokia E71-1 Failed even using Code Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0871221 Using device: HTI, FW ver: 00.50, SN: 01005DAE Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 16F0011368A600529F3A81CF23DA5F4D57C3B0BA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7 Selected firmware certificate matched. Original Imei: 35485604068847 Original Product code: 0570193 Bluetooth ID: 2CD2E7A3591F SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL3 Phone type: RM-346 (Nokia E71) SW version: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia ApeCoreSw: 300.21.012 Imei plain: 35485604068847-2 Product code: 0570193 Battery voltage: 4755 mV, current: 0 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354856040688472 Version: SIMLOCK SERVER Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 10/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] Phone already downgrade but still cant unlock it. Invalid codes Code: #pw+ 065113715418028 +1 # #pw+ 757777900652158 +2 # #pw+ 330867030706940 +3 # #pw+ 927736655492176 +4 # #pw+ 708362126652341 +5 # #pw+ 951880787753173 +6 # #pw+ 930135231334896 +7 # |
03-11-2013, 10:43 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. You have to contact Service Provider to Unlock this Phone, Codes will not work in this Case. BR, ZUBER |
