02-22-2010, 17:04 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: QQ:2557307931
Member: 1010502 Status: Offline Sonork: whats this?! Thanks Meter: 316 | !!! [+] Updating SIMLOCK ... error 0x1 100% SOLUTION !!! First method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Repair SIMlock with MXKey 6 - Repair Superdongle with MXKey 7 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) The second method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Lock the by phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 6 - Repair SIMlock with MXKey 7 - Repair Superdongle with MXKey 8 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) Third method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Erase Eeprom Section: Flashing-> Advance-> GetAddress, Disable Safe Erase. Enable Eeprom Part only, Click Erase. 3 - Locke the phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 4 - Repair SIMlock with MXKey 5 - Repair Superdongle with MXKey 6 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) BR. www.Forum.**********.com |
The Following 33 Users Say Thank You to Y.P.Y For This Useful Post: |
02-22-2010, 19:32 | #6 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
thanks very much for your clean steps .. but please also make this clear ... how to 2 - Full Erase with MXKEY , which options to check ? how to Restore only NPC Backup Part with mxkey ? how to Repair SIMlock with MXKey, which settings do we have to click ? thanks please reply... | |
02-23-2010, 08:00 | #7 (permalink) | |||
Member: 1010502 Status: Offline Sonork: whats this?! Thanks Meter: 316 | Quote:
Code: [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0547930 PSN=MIH117589 HWID=0602 NPC_DATA_1=CBFC673F000041500000000000000000000000000000000000000000303534373932384300000000 NPC_DATA_2=0000000000000000000000003346E094FA461047D4CF1200646F72420000000002F00013116E0058 NPC_DATA_3=BC4E083C54815DB7273C7CDD0FE1BA92D924A658E4800780FA6F4868100AC947F5C552976DB59613 NPC_DATA_4=2AD4D86075AA7240202F22D1000000000000000000000000000000000200000047534D0000000000 NPC_DATA_5=3385460031171698FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=7AE6E86E1D00000000000000000000000000000000000000000000000000000028D21F9649B9C9E5 NPC_DATA_7=B55EA03E8C3A345EA95AFD137A1B14C3DD2DE374BCED611B17F0FB04D267EA74D02277C292507CC2 NPC_DATA_8=596D9CB01D0755DEA9D6D7932D306E5F200BD9CC9E5E994D5AE5B517AB4447BFF3E351E2A9A7A5FB NPC_DATA_9=5C0B50052474EE6154235B1E0AFCC6004A1B0D520E80F2A2E3D4621686A648C1E5752DCD4538C472 CCC_DATA_1=4343434302004150010000009138E094C4D94A463A6C290067889C00000060010000000038B1AC45 CCC_DATA_2=00000000000000000000000000000000000000000000000000000000000000003035343633333343 CCC_DATA_3=38B1AC450000000000000000030000000F0000001100000000000000000000000000000000000000 CCC_DATA_4=00000000000000000000000000000000000000000000000000000000000000000000000000000000 CCC_DATA_5=00000000000000000000000000000000000000000000000000000000000000000000000000000000 CCC_DATA_6=000000000000000000000000000000000000000000000000BAFD4259326617A15CA1194C5E31D686 CCC_DATA_7=9F42C9C5A2FFADCC0CB21D2273261C44CB8D3EA5A5FD892A62C0096C25544E0C3B19FB28FACCB0C8 CCC_DATA_8=FAF829A473CDC7AD9A05F36144F9B7BA511CE17749E2A6B05F86411C6209E34A0ABC3FFF8CED9CCC CCC_DATA_9=46DED5B87B1792F50A29BB88A9EE8A29D312D3208E903D91237F03A8E3E8C99A HWC_DATA_1=4348574305004150010000003346E094FA4610470000000000000000000000000000000000000000 HWC_DATA_2=000000000000000002F00013116E0058BC4E083C54815DB7273C7CDD303534373932384300000000 HWC_DATA_3=0000000055325E23434E53AEEC20D306946F94E35BE86E63E2DD9C2309C9D17BE61D614BE5F7015F HWC_DATA_4=C7DC9513132BF6469EBA1753B341709FEA2B6E8CBE2B5B4A970AB586D03A35BD41DF002741DB79D3 HWC_DATA_5=5170F99B253323A7A0AA7CCD4BC26204E0C34775735A92A1C6EA9FC4B6E18CF0DBBB63819DF89B53 HWC_DATA_6=BFE9546FDB8C73E6DB6DE105 SIMLOCK_DATA_1=8D15652AF81FAD349B84440CEAAD97D8DD17601F0000000000000000244070000000000000180700 and more... Modified RPL(only NPC Part) Code: [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0547930 PSN=MIH117589 HWID=0602 NPC_DATA_1=CBFC673F000041500000000000000000000000000000000000000000303534373932384300000000 NPC_DATA_2=0000000000000000000000003346E094FA461047D4CF1200646F72420000000002F00013116E0058 NPC_DATA_3=BC4E083C54815DB7273C7CDD0FE1BA92D924A658E4800780FA6F4868100AC947F5C552976DB59613 NPC_DATA_4=2AD4D86075AA7240202F22D1000000000000000000000000000000000200000047534D0000000000 NPC_DATA_5=3385460031171698FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=7AE6E86E1D00000000000000000000000000000000000000000000000000000028D21F9649B9C9E5 NPC_DATA_7=B55EA03E8C3A345EA95AFD137A1B14C3DD2DE374BCED611B17F0FB04D267EA74D02277C292507CC2 NPC_DATA_8=596D9CB01D0755DEA9D6D7932D306E5F200BD9CC9E5E994D5AE5B517AB4447BFF3E351E2A9A7A5FB Quote:
Goto Service -> imei & security -> Simlock -> check Repair Simlock -> Click Repair SPLock | |||
02-23-2010, 08:07 | #8 (permalink) |
No Life Poster Join Date: Oct 2009 Age: 37
Member: 1149013 Status: Offline Thanks Meter: 247 | 5130c is sl3 can i repire simlock cruppted can i solve this problem chk this link bro Y.P.Y http://forum.gsmhosting.com/vbb/showthread.php?t=934095 |
02-23-2010, 09:21 | #9 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
No Bro Can not repair,,,bcoz not supported yet. BR | |
02-23-2010, 09:25 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Br, Updating SIMLOCK ... error 0x1 100% SOLUTION WITH MXKey Here is the Another Solution Without erase, First method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Just Downgrade the phone 3 - Repair SIMlock with MXKey |
02-23-2010, 15:39 | #12 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 07.21 05-11-08 RM-237 (c) Nokia. Using cached productData[2150021335B47C56125FAFF9F3D57862D810C45A] ... Calculating SIMLOCK using security server ... Completed in 1.781 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_3568520---------_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 3568520---------- Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF i have a 3110c which i am unable to repair with all the three methods given above .. can u help me ? |
02-23-2010, 20:31 | #13 (permalink) | |
5130 Updating SIMLOCK...error 0x1 | bhaskarsha | Nokia Base Band 5 ( BB-5 ) | 23 | 09-11-2011 18:51 |
!!! [+] (3110) Updating SIMLOCK ... error 0x1 100% SOLUTION (Video Manual) WITH MXKey | swechacnu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-29-2010 10:02 |
Updating SIMLOCK ... error 0x1 100% SOLUTION | Jilani001 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-24-2010 14:01 |
5220 Updating SIMLOCK...error 0x1[SOLVED] | gsmfeng | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 02-09-2010 09:19 |
