01-11-2012, 21:46 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Salvador - BA - Brazil Age: 37
Member: 1010981 Status: Offline Sonork: 100.1614537 Thanks Meter: 47 | USB ROM Not Remove user code. This is Log: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C0811DC1 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000**** Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.72 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000D32B051F2553D4CB8D211B3A13A7D8 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: E1852D4 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Original Imei: 358628041***** Original Product code: 059B756 Bluetooth ID: 04A82A2E5C2C SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ...OK [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: E1852D4 Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: E1852D4 FULL FACTORY... Failed! (0004) Completed in 0.890 s FULL FACTORY... Failed! (0004) Completed in 0.765 s FULL FACTORY... Failed! (0004) Completed in 0.719 s |
01-16-2012, 11:05 | #2 (permalink) |
Insane Poster Join Date: Jan 2006
Member: 218868 Status: Offline Thanks Meter: 5 | same problem...X2-01 + x2-00 having same problem. old version Mxkey not ask ...... "[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! After press ok or accept i get.... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13992EE Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13992EE service lights up...but always....FULL FACTORY... Failed! (0004) |
01-16-2012, 12:41 | #3 (permalink) |
Member: 1010981 Status: Offline Sonork: 100.1614537 Thanks Meter: 47 | That's right my friend. Once updated the mx-key for the 1.7 it does not remove User Code. This new function that switches on after the flash is only good for other opeções, and not removing code. Does anyone have any solution? |
01-18-2012, 08:56 | #4 (permalink) |
Member: 218868 Status: Offline Thanks Meter: 5 | C3-00 same problem NOT DOING SECURITY CODE ON C3-00 ALSO. SYNRONISE DONE HERE LOG... Definitions file is identical and up to date, no need an update. FLASHED HERE LOG... MXKEY [FT SCR2000 0], SN: Using device: USB ROM Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.70 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Processing MCU file: rm614__08.63.mcusw [BB5,XSR 1.6] size: 27.90 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 00000000003468E2433E1A798FEF5633278BBE8E CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13992EE FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35536604325752_CE RT.rpl). CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 33.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-012FFFFF] CMT FLASH,MuxOneNAND area [01300000-01DFFFFF] CMT FLASH,MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 697F7477 [RAP Certificate v1 232] sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 8.859 s Processing PPM file: rm614__08.63.ppm_e1 [BB5,XSR 1.6] size: 6.63 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 2.140 s Processing CNT file: rm614__08.63.image_e1_0593947_v2 [BB5,XSR 1.6] size: 13 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT FLASH,MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 3.563 s Total time for flashing process(boot+erase+write) was 23.985 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13992EE Waiting for USB device removal ... Warning: Phone did not reboot to normal mode. |
01-18-2012, 09:00 | #5 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Pakistan & Bahrain Age: 37
Member: 617073 Status: Offline Sonork: 100.1611349 Thanks Meter: 316 | Quote:
use latest flash file and try again | |
01-18-2012, 09:08 | #6 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | Quote:
01-18-2012, 10:49 | #7 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
01-18-2012, 16:34 | #8 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 411034 Status: Offline Thanks Meter: 26 | Quote:
same for me for x2 ca,nt open scurity code with usb | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
sp lock 1,2,3,4 removed | spterminator | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 08-09-2010 10:20 |
