03-27-2010, 13:09 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 407630 Status: Offline Thanks Meter: 36 | WHY n96 flashed dead with MX-rev1.7fixed? Version from phone: ICPR72_09w13.3 Version from file: 30.101 Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\BB5_35640602555581_BA CK.rpl). APE Data : SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x] ASIC MODE ID: 00 PUBLIC ID: FFEE72368BF0D120BD291D01E5CB7D837B5F7137 ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 05D00110C16B0052F091569320CDEA6B28383E56 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE ALG [35]: N8815 ALG STNFMS Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE Erase size: 179.03 MB CMT NOR area [00080000-007A6EE9] CMT NOR area [00000000-0005FFFF] CMT NOR area [00880000-00EFFFFF] APE NAND area [00000000-0007FFFF] APE NAND area [00080000-000BFFFF] APE NAND area [000E0000-0045FFFF] APE NAND area [00840000-0A8FFFFF] erased in 39.615 s Erase size: 34.50 MB APE NAND area [07780000-099FFFFF] erased in 0.085 s Erase size: 15.00 MB APE NAND area [09A00000-0A8FFFFF] erased in 0.086 s Erase size: 64.00 KB Formating Partition ... erased in 0.327 s Erase completed in 41.800 s Flash programming ... CMT PAPUBKEYS: AD7799ABC45695918C0B8E955FAD5FF12650E6AE (RAP Certificate 62 v1) written. APE PAPUBKEYS: AD7799ABC45695918C0B8E955FAD5FF12650E6AE (APE Certificate 62 v1) written. Error while programming [01] at 0x01998800, Result: 0000 Flashing terminated with error(s) in 10 min 31.714 s |
The Following 2 Users Say Thank You to xiakaijun For This Useful Post: |
03-27-2010, 13:16 | #2 (permalink) |
Member: 407630 Status: Offline Thanks Meter: 36 | after this i want to alive with mt-box,but got it: Boot... Using Tx2 Data line. Trying boot BB5 phone... RAPIDOv11_2nd.fg RAPIDOv11_XSR15_alg.fg Delay for loader to take control... BOOT OK CMT New Protocol STn8815_2nd.fg STn8815_STNFMS_alg.fg Command reset failed, using HW switch. Trying boot DCT4 phone... ============= Set FBus mode for info ============= VBat is 4.01V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 VPP is DISABLED. Using Tx2 Data line. Processing File: RM-247_30.101_prd.core.fpsx Boot... RAPIDOv11_2nd.fg RAPIDOv11_XSR15_alg.fg STn8815_2nd.fg STn8815_STNFMS_alg.fg %%%%%%%% ERROR BOOTING: |
03-27-2010, 13:21 | #3 (permalink) |
Member: 407630 Status: Offline Thanks Meter: 36 | the same time,when check 5000 rm-362 with mx i faced error ,again. Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Error flash config request! |
04-26-2010, 14:56 | #5 (permalink) | |
Freak Poster Join Date: Sep 2003 Location: Romania, Satu Mare
Member: 38276 Status: Offline Thanks Meter: 35 | Quote:
04-29-2010, 08:45 | #7 (permalink) |
No Life Poster Join Date: Jun 2004 Location: sure...not at heaven... Age: 57
Member: 67494 Status: Offline Thanks Meter: 71 | still problems mr manole,plz tell me how to solve,the n96 is now in white display and shut down,phone are brande new just need update. |
04-29-2010, 08:58 | #8 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
your phone is brand new. so i hope you're not downgrading it improperly. Latest firmware for N96_RM-247 is 30.033. Select the phone type, press Image DL BR | |
N96 UNLOCK SUCCESSFUL WITH MX KEY NEW V3.3rev1x | palash_c6 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 01-22-2010 08:51 |
NOKIA 3500c DEAD USB FLASHING PROBLEM WITH MX-KEY:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-14-2009 12:43 |
My first dead usb flashing sucessfull with mx-key:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 06-12-2009 11:01 |
Can we expect new security like n96,95 unlocking with MX-KEY | sairat | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-21-2009 11:09 |
Dead n96 flashed successfully with usb | faisal_sherry | MT-BOX | 11 | 11-04-2008 10:39 |
