Old 02-04-2010, 13:22   #1 (permalink)
Member: 923652
Sonork: 1601428
Thanks Meter: 89
want to help mxkey and make more faster and easier to fix contact service how?
How to help MX-KEY AND USER'S READ CAREFULLY!!!
read this:
Originally Posted by MANOLE View Post
If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!".
This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...).
Solution 1 (easy way, maybe not work all time, depends how phone was damaged):
- write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones)
- unplug/replug phone from JAF/UFS box
- make Simlock RPL repair
- make SD RPL repair
- make SUPER SX4 Auth then write PM1 and PM309
if still have problems, use Solution 2:
- backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL
- backup RPL from another working phone (same model) with SAME product code
- edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL
- backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM
- full erase flash chip (use erase file regarding flash chip size)
- flash phone (CMT, APE, ...)
- upload CLONE RPL
- upload ORIGINAL RPL
- write full CLONE PM without fields 1,120,308,309
Manole
please if you have working sl_2 and sl_3 phone working 100%
please backup your " FULL PM" and upload to this thread
you will make contribution and way to fix contact service easily
let me be the one to start
: 5320d-1
Phone Type: RM-409 (Nokia 5320)
SW Version: V 08w35.08 28-11-08 RM-409 (c) Nokia
Imei plain: 3557400281****-8
Product Code: 0562470
ApeCoreSw: 04.13
Language Pack:
- not available.
SIMLOCK seems to be valid
SECURITY_TEST passed
"C:\Program Files\Nokia\Phoenix\Products\RM-409" folder created.
Imei net: 3557400281****8
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
regards
mx-key users
br.
..:: liGhts17::.. and tsambakol team
The Following User Says Thank You to ilaw For This Useful Post:
Old 02-04-2010, 13:58   #2 (permalink)
Crazy Poster
Member: 1226388
Sonork: jk khan
Thanks Meter: 13
Originally Posted by ilaw View Post
how to help mx-key and user's read carefully!!!
read this:
Please if you have working sl_2 and sl_3 phone working 100%
please backup your " full pm" and upload to this thread
: 5320d-1
phone type: Rm-409 (nokia 5320)
sw version: V 08w35.08 28-11-08 rm-409 (c) nokia
imei plain: 3557400281****-8
product code: 0562470
apecoresw: 04.13
language pack:
- not available.
Simlock seems to be valid
superdongle_key seems to be valid
security_test passed
"c:\program files\nokia\phoenix\products\rm-409" folder created.
version: Simlock server
provider: Nokia test, country: Finland
counter: 0/3, 0/10
config_data: 2440700000000000
profile_bits: 0000000000000000
block 1:   1=open 2=open 3=open 4=open 5=open, data=ffffff
block 2:   1=open 2=open 3=open 4=open 5=open, data=ffffff
block 3:   1=open 2=open 3=open 4=open 5=open, data=ffffff
block 4:   1=open 2=open 3=open 4=open 5=open, data=ffffff
block 5:   1=open 2=open 3=open 4=open 5=open, data=ffffff
block 6:   1=open 2=open 3=open 4=open 5=open, data=ffffff
block 7:   1=open 2=open 3=open 4=open 5=open, data=ffffff
regards
mx-key users
br.
..:: Lights17::.. And tsambakol team
waste of time
above solution is not working.
The Following User Says Thank You to gsm_telangana For This Useful Post:
Old 02-06-2010, 05:03   #3 (permalink)
Member: 343232
Thanks Meter: 22
e2 n81 8g
full pm w/pm 120 ,308,309
Phone Type: RM-179 (Nokia N81)
SW Version: V 06wk41v47.2 23-11-07 RM-179 (c) Nokia
Imei plain: 35699501246489-8
Product Code: 0545896
ApeCoreSw: 11.0.045
ApeVariant: 11.0.045, ApeTest: rm179_ENO_x_2007wk24v0.070
Language Pack:
- not available.
SIMLOCK_TEST passed
"RM-179" folder created.
Imei net: 356995012464898
Counter: 0/3, 0/10
pm files here>>http://www.sendspace.com/file/eeqy8u
The Following User Says Thank You to x_commwarrior_x For This Useful Post:
nokia 7210c contact service how to fix ? milandhal Nokia Base Band 5 ( BB-5 ) 28 05-19-2011 17:54
5220 XM Contact Service,How to Fix? Sniper_04 Nokia Base Band 5 ( BB-5 ) 4 01-26-2010 06:07
<<< 7210c Contact Service - How to Fix This Fault >>> khadim100 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 12-05-2009 08:20
7210 contact service HOW TO FIX?????? essojay Nokia Digital Core Technology 4 ( DCT-4 ) 2 05-14-2006 17:09
how to fix contact service by griffin thanhit Griffin 3 12-23-2004 08:49
Page generated in 0.17667 seconds with 9 queries
