05-05-2009, 04:52 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Philippines
Member: 230087 Status: Offline Thanks Meter: 373 | What A Discovery From MX-Key!!!! The PCB were clean... No repair whatsoever. But the problem is it shows "CHARGING NOT SUPPPORTED" and AUTOMATICALLY TURN OFF EVERY 5-10 minutes. How do I solved this problem using MX-KEY? Simple. Everytime I try to use pm auth of mx-key it shows "SUPERDONGLE KEY ERROR" What I did is Reset its NPC (turning rpl to 123456789...?) then with the help of 3rd party rpl logger, I buy BB5 RPL and write it to pone.... Result.... PROBLEM SOLVED! The thing is, through MX-Key I discovered that (maybe... I'm no expert in this...) the fault is caused by a damaged or corrupted RPL although IMEI of these handsets is not 123456...? Thanks to MX-key, now I have a means to repair this problem on bb5 models... I hope someday MX-key will provide BB5 RPL Calculation in the future so that I will not need 3rd party providers... |
05-05-2009, 04:56 | #2 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Marikina City
Member: 293270 Status: Offline Thanks Meter: 43 | yes thats true... if imei is 123456.... then you have to use third party rpl... i tested it on 6300 wherein phone pcb is clean but shuts off when i open gallery aor i use the camera... |
05-06-2009, 00:04 | #3 (permalink) | |
Freak Poster Join Date: Apr 2007 Location: land of no return
Member: 486967 Status: Offline Sonork: none Thanks Meter: 17 | Quote:
how to download flash file from mx-key server? | Brother Hui | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-03-2010 11:12 |
Sd repair free coming from mx-key.any news from others device. | shahinahmed007 | Nokia Base Band 5 ( BB-5 ) | 1 | 02-03-2010 10:44 |
see this error from mx key... | Rin2 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-27-2009 15:10 |
I Can't Download flash file from MX Key Support Area,hope you can help me Mr. Manole | makasa | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 12-20-2009 23:27 |
Guyz what you think about mx key ???? | mani2050 | Nokia Base Band 5 ( BB-5 ) | 3 | 12-12-2009 06:44 |
