Old 08-19-2010, 13:07   #1 (permalink)
Member: 197485
Thanks Meter: 19
5130 all ok but phone cs ????
the phone is contact service . what I can do???
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1D0001157895465028ED087FFDB3EC72B392B3BE
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Original Imei: 35937103108019
Original Product code: 0576625
Bluetooth ID: A87B39A40390
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 35937103108019-7
Product Code: 0576625
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359371031080197
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 08-19-2010, 13:14   #2 (permalink)
Member: 998867
Sonork: chuchu
Thanks Meter: 24
try to flash the phone.................
Old 08-19-2010, 13:17   #3 (permalink)
Member: 197485
Thanks Meter: 19
I tried before but the same
Old 08-19-2010, 13:21   #4 (permalink)
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,488
plz post selftest also...
Old 08-19-2010, 13:28   #5 (permalink)
Member: 197485
Thanks Meter: 19
Phone Type: RM-495
SW version: V 07.91 29-10-09 RM-495 (c) Nokia
ID Test name Startup Result
3 EAR_DATA_LOOP Y !failed !
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
15 SLEEP_X_LOOP Y passed
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N passed
20 BACKUP_BATT N passed
43 LCD N passed
21 LPRF_IF N passed
44 LPRF_AUDIO_LINES N passed
2 CURRENT_CONS N passed
42 RADIO N passed
69 BACKLIGHT Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
71 BT_WAKEUP N passed
96 HOOKINT N passed
88 TAHVOINT Y passed
101 BTEMP N passed
119 IIC N passed
108 EXT_DEVICE N passed
56 CDSP_SLEEPCLK_FREQ N passed
128 CDSP_SLEEPCLOCK_FREQ N !no signal
86 CDSP_RF_BB_IF N !no signal
83 CDSP_RF_SUPPLY N !no signal
80 CDSP_TX_PLL_PHASE_LOCK N !no signal
81 CDSP_RX_IQ_LOOP_BACK N !no signal
77 CDSP_GSM_TX_POWER N !no signal
Old 08-19-2010, 13:33   #6 (permalink)
Cheater -Don't Deal with him-
Member: 1179761
Sonork: 100.1602000
Thanks Meter: 1,834
Arrow
Originally Posted by د.نابغ View Post
Phone Type: RM-495
43 LCD N passed
21 LPRF_IF N passed
42 RADIO N passed
96 HOOKINT N passed
101 BTEMP N passed
119 IIC N passed
Resold Retu Ic 100% solved
The Following User Says Thank You to nerobdms™ For This Useful Post:
Old 08-19-2010, 13:49   #7 (permalink)
Member: 197485
Thanks Meter: 19
ok I will try
thanks
Old 08-19-2010, 13:54   #8 (permalink)
Member: 998867
Sonork: chuchu
Thanks Meter: 24
i think betty ic problem...... rehot
Old 08-19-2010, 16:01   #9 (permalink)
TICTAC_M's Avatar
Member: 331361
Thanks Meter: 155
trid it first.
with auth sx4 write pm with out sim lock.
File Type: rar Modified_120_308_Removed_RM-495_353223036123751.rar (2.8 KB, 116 views)
The Following User Says Thank You to TICTAC_M For This Useful Post:
Old 08-19-2010, 16:53   #10 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
1 step }pm auth sx4 write pm and repair sim lock
2 step Resold Retu Ic or change. i thinks your problem solve
Old 08-19-2010, 17:04   #11 (permalink)
nokia-ps's Avatar
Member: 801286
Thanks Meter: 54
clean the bord and hot all ok
Old 08-19-2010, 18:13   #12 (permalink)
y2y
y2y's Avatar
Member: 166000
Thanks Meter: 26
5130 uses avilma and betty !!!
my opinion with " ear data loop failed " is avilma problem, cause audio part inside avilma not betty.
Old 08-19-2010, 20:01   #13 (permalink)
Member: 197485
Thanks Meter: 19
thanks all
I think it is hardware problem
I deal with customer then I will open the phone
Old 08-19-2010, 22:19   #14 (permalink)
Member: 392149
Thanks Meter: 199
How can repair sim lock nokia 5130 U know it is SL3 model
lolllllllllll
Old 08-20-2010, 03:56   #15 (permalink)
Member: 205474
Sonork: 100.1585171
Thanks Meter: 97
no sol yet in any box for sl3 simlock repair
w8 for sol
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.20980 seconds with 10 queries
