Member: 172261
Thanks Meter: 364 | What's wrong with this 2700c (ANSWERED) [bus check] Quote:
mxkey [mxkey team hti flasher interface (winusb) 1], sn: C0808888
using device: Hti, fw ver: 00.50, sn: 00008888
connection status: Uhci:hub:usb 2.00 (full-speed)
driver: Winusb, ver: 3.5.0.0
module ver: 1.0.0.19663(13-12-2011), library ver: 1.0.0.13682(17-12-2011)
cmt data :
System asic id: 000000010000022600010006030c192101033000 [rap3g ver: Pa 3.x]
em0 id: 00000296
em1 id: 00000b22
public id: 2500020f9a584e5032d5***2674a23c7e4b92349
asic mode id: 00
root key hash: 9ddbfcfe6e73ced7d8c6268c8eb85723
rom id: 273f6d55dfaaf68f
secondaryboot: Rap3gv3_2nd.fg [***] version: 10.42.0 revision: 0.0 size: 0x3c40
supported ids: 0103192101003000, 010c192101003000, 0103192101013000, 010c192101013000, 0103192101003100, 010c192101003100, 0303192101023000, 030c192101023000, 0303192101033000, 030c192101033000, 0103192101001101, 010c192101001101, 0003192101001002, 000c192101001002, 0013192101001002, 001c192101001002
e***protocoltype: Old
storage0: 00ec 2400 - 0000 8a31 [samsung ] type: Flash,nor, asic:cmt
storage content: 0000 0000 0000 0000 0000 0000 0000 0000
storage1: Ffff 0000 - 0000 0000 type: Mmc, asic:cmt
transmissionmode: 16bit
algorithm: Rap3gv3_algo.fg [*** algorithm] version: 10.40.0 revision: 0.0 size: 0x23550
supported ids: 0103192101003000, 010c192101003000, 0103192101013000, 010c192101013000, 0103192101003100, 010c192101003100, 0303192101023000, 030c192101023000, 0303192101033000, 030c192101033000, 0003192101002000, 000c192101002000, 0003192101002100, 000c192101002100, 0003192101002200, 000c192101002200, 0003192101012200, 000c192101012200, 0103192101001101, 010c192101001101, 0003192101001002, 000c192101001002, 0013192101001002, 001c192101001002
cmt papubkeys hash: 3ea22a1dda660002e56108db5072a10f8709443f
transmissionmode: Ddr&tx2
original imei: 35339404527890
original product code: 0579808
bluetooth id: 80501b725ae5
phone type: Rm-561 (nokia 2700 classic)
sw version: V 09.98 06-09-10 rm-561 (c) nokia
imei plain: 35339408888880-0
product code: 0579805
battery voltage: 4736 mv, current: 131 ma
language pack:
- not available.
Slpa ver[4]: Pa_sl3/pa_simloc30 (15 digit nck)
warning: Avoid sw downgrade & manual erase to this phone !
Camera config: Nimmiiiirrff0a021001, ver: 002.007
simlock seems to be valid
superdongle_key seems to be valid
cmla_key seems to be valid
wmdrm_pd seems to be valid
simlock_test passed
security_test passed
imei net: 353394088888800
version: Simlock server
counter: 0/3, 0/10
config_data: 2440700000000000
profile_bits: 0000000000000000
block1: 1=open, 2=open, 3=open, 4=open, 5=open
block2: 1=open, 2=open, 3=open, 4=open, 5=open
block3: 1=open, 2=open, 3=open, 4=open, 5=open
block4: 1=open, 2=open, 3=open, 4=open, 5=open
block5: 1=open, 2=open, 3=open, 4=open, 5=open
block6: 1=open, 2=open, 3=open, 4=open, 5=open
block7: 1=open, 2=open, 3=open, 4=open, 5=open
| [scan] Quote:
battery voltage: 4881 mv, current: 51 ma
language pack:
- not available.
simlock_test passed
counter: 0/3, 0/10
| [flash] Quote:
version from phone: 09.98
version from file: 09.98
rpl backup already exist (d:\mobileex\3.5\data\backup\***_35339408888880_ba ck.rpl).
Cmt data :
em0 id: 00000296
em1 id: 00000b22
asic mode id: 00
processing mcu file: Rm561__09.98.mcusw
[***,*** algorithm] size: 19.41 mb
supported ids: 010c192101013000, 0103192101003000, 030c192101033000
storing certificate [npc, variant, r&d, ccc, hwc] ...ok
erase size: 21 mb
cmt flash,nor area [00000000-000006bf]
cmt flash,nor area [000006c0-0001ffff]
cmt flash,nor area [00040000-000bffff]
cmt flash,nor area [000c0000-0013ffff]
cmt flash,nor area [00140000-0137ffff]
cmt flash,nor area [01380000-0151ffff]
erased in 1 min 13.677 s
prog.status for asic cmt ...
Nor: Ok
flash programming ...
Cmt nolo block sent
cmt keys block sent
cmt primapp block sent
cmt pasubtoc block sent
cmt papubkeys: 3ea22a1d [rap certificate 202 v.1] sent
cmt updapp block sent
cmt dsp0 block sent
cmt mcusw block sent
Nor: Ok
programming completed in 1 min 22.140 s
processing ppm file: Rm561__09.98.ppm_s
[***,*** algorithm] size: 7.21 mb
erase size: 8.62 mb
cmt flash,nor area [01520000-01dbffff]
erased in 27.072 s
Nor: Ok
Prog.status for asic cmt ...
Nor: Ok
programming completed in 30.728 s
processing cnt file: Rm561__09.98.image_s_blac
[***,*** algorithm] page size: 128 k size: 13.64 mb
erase size: 34 mb
cmt flash,nor area [01dc0000-0215ffff]
cmt flash,nor area [02160000-03fbffff]
erased in 1 min 41.022 s
Nor: Ok
Nor: Ok
programming completed in 58.431 s
total time for flashing process(boot+erase+write) was 6 min 20.788 s
after flash processing ...
Updating product code ok.
Reseting warranty and lifetimer ok.
Reseting factory values ok.
Phone type: Rm-561 (nokia 2700 classic)
battery voltage: 4717 mv, current: 83 ma
language pack:
- not available.
simlock_test passed
counter: 0/3, 0/10
| after flash still auto off few second, only see set time & date |
