06-19-2011, 08:12 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: India (Gujarat) Age: 36
Member: 223135 Status: Offline Sonork: 100.1592685 Thanks Meter: 177 | Successful flashing X2-01 Fast Flashing Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: rm709__07.11.mcusw [BB5,XSR 1.6] size: 26.59 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 37A1EEE CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000BAA9A21E7EC125E3B3946B5EA1EDC2 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0010 0011 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 37A1EEE Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35625604716223_CE RT.rpl" CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 Storing certificate [NPC, CCC, HWC, RND, R&D] OK. Partitioning.... Partitioning complete Erase size: 33.88 MB CMT MuxOneNAND area [00000000-0001FFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 37955B6FC432998EF0DB240E332228384D19ED09 () sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 6.344 s Processing PPM file: rm709__07.11.ppm_mn1 [BB5,XSR 1.6] size: 6.13 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 1.344 s Processing CNT file: rm709__07.11.image_mn1_059C3V1 [BB5,XSR 1.6] size: 29.34 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 6.953 s Total time for flashing process(boot+erase+write) was 28.641 s Waiting for device boot up ... Device found: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 574A97B Verifying communication to device OK. Phone Type: RM-709 (X2-01) SW Version: V 07.11 22-12-10 RM-709 (c) Nokia Imei plain: 35625604716XXX-X Product Code: 059D363 Battery voltage: 4077 mV, current: 1 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35625604716XXXX Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
The Following User Says Thank You to uttam For This Useful Post: |
06-19-2011, 08:29 | #5 (permalink) | |
No Life Poster Join Date: May 2009 Location: On My KeyBoard
Member: 1038860 Status: Offline Sonork: 100.1593889 Thanks Meter: 173 | Quote:
BR Smarty3399 | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Need solution for 3210 v5.01 | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-20-2000 21:55 |
