Old 06-04-2010, 15:40   #1 (permalink)
Member: 3508
Thanks Meter: 71
SERVER problem - working or not!?!?
Hi!
I can't see server list. When I click on it nothing shows up...
So I can't unlock DCT4+, it also doesnt find server!!
So is the server working or not!?
Old 06-04-2010, 16:29   #2 (permalink)
Member: 621121
Thanks Meter: 366
i think now it's down
Old 06-04-2010, 20:46   #3 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
This is not a thinking time.
The server is worked for me perfectly.
Br.
Vijendra Saini.
Old 06-04-2010, 22:14   #4 (permalink)
Member: 3508
Thanks Meter: 71
Br.
Vijendra Saini.
It worked for me too, but the question is, is it working now!?!?
I still can't connect to server!!!
Old 06-04-2010, 22:19   #5 (permalink)
Member: 606545
Server list sir pl help me
Old 06-04-2010, 22:20   #6 (permalink)
Member: 606545
Ms key server list not at come
Old 06-05-2010, 03:11   #7 (permalink)
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Wink
I already explain here,server is working fine for me right now,but i have to do all procedure 3 or 4 times,then its worked for me 1 time
May be server load problem.
Br.
Vijendra Saini.
Old 06-05-2010, 06:54   #8 (permalink)
Member: 1241675
Sonork: 100.1583896
Thanks Meter: 20
server is fine and work fine for me no problem please check internet connection.
Old 06-05-2010, 06:59   #9 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
DEAR FREINDS ONLY ONE SX4 SERVRE IN OFFLINE OTHERS WORKING FINE
Old 06-05-2010, 07:12   #10 (permalink)
..::\/\/::..'s Avatar
Member: 1294131
Sonork: 16919899
Thanks Meter: 579
mxkey server problem
chang imei 2600c (server imei not sport)
The Following 2 Users Say Thank You to ..::\/\/::.. For This Useful Post:
Old 06-07-2010, 15:41   #11 (permalink)
Member: 3508
Thanks Meter: 71
I have found the solution for server problem in MobileEx v 3.4
do As directed:
1. Uninstall al the previous versions including v 3.4
2. Delete manually The directory c: mobileEx 3.x.
3. Search in c drive for mobileex*.*
4. Delete all the files.
5. Install mobileEx 3.4 again.
6. sign application.
7. You are ready to go.
And server list works without problem!!
PS. Some internet providers block some MX servers so you must use proxy if this solution doesn't help!!
The Following 2 Users Say Thank You to GSMBlade For This Useful Post:
Old 06-07-2010, 17:46   #12 (permalink)
tunningcel's Avatar
Member: 204098
Thanks Meter: 10
Lightbulb Server base tools working again
This works just fine for me, so maybe there is not a server problem but a sw bug?
do As directed:
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.30167 seconds with 9 queries
