05-12-2009, 09:21 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Philippines
Member: 230087 Status: Offline Thanks Meter: 373 | When you get this error.... it means ASIC ID: 0x1120 [UPP8M_v3.0 ] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 257E [AMD 29BDS643GT] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF u_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0059B849:C421DA60 Programming MCU ... rh9__05.350: [DCT4][DCT4 ALGORITHM] (5.15 MB) Supported Ids: 0121, 0120, 1120 Area [01000000-0100FFFF] erased in 0.641 s Area [01010000-017EFFFF] erasing ... Error while erasing 0x01170000-0x0118FFFF, Result: 04000000 Flashing done with error(s) in 37.328 s RX Buffer: 0400000000B172 When you get this error.... it means faulty: 1- CABLE OR INTERFACE 2- RAM 3- FLASH IC |
05-12-2009, 14:56 | #2 (permalink) | |
Member: 230087 Status: Offline Thanks Meter: 373 | Quote:
This applies also in WD2 & BB5.... In BB5, mostly I get this error due poor cable quality and interface which I used (jaf, UFS...) | |
05-12-2009, 17:42 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | this error 80% from interface 3.2 version still have bugs as i found many time the perfect interface working with me is ufs with frimware 2.8 but some times u will need jaf interface mt interface still noot goood with dct4 and its not support bb5 flash hope new update will come soon |
02-09-2010, 15:57 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | And sir what is this error flash with Jaf complete but phone start up failed contact the retailer.... here is mxkey logs.... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 0094FE6C:2984DA7E Area [00000000-00FFFFFF] erased in 2 min 19.000 s Area [02000000-02FFFFFF] erased in 2 min 18.219 s Area [04000000-047FFFFF] erasing ... Error while erasing 0x04600000-0x0461FFFF, Result: 04000000 Process failed ! |
02-09-2010, 16:24 | #5 (permalink) |
Insane Poster Join Date: Jun 2009
Member: 1059105 Status: Offline Thanks Meter: 15 | i can't make my twister work with mobileEx 3.3 and UFS_DCTxBB5 when using Mx-Key driver for twister i can't use twister with UFS_DCTxBB5 and same way when using UFS_DCTxBB5 driver ... any help at solving this problem ... |
W910 error how fix this or when you fix this becouse I lost now credits !! !! !! | wgmmmx | Universalbox | 5 | 06-25-2008 20:54 |
Pls Uni Team, can you tell me what this error code means? | mtb116 | Universalbox | 2 | 08-05-2006 02:12 |
6600 when trying to write flashe i get this error | iyass | Federal One | 5 | 03-16-2004 00:36 |
