Old 01-17-2011, 19:01   #1 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
Question all bb5 by rj45 to flash fail why ?
check this please always same problem
with new version
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011)
Processing MCU file: rm495__06.65.mcusw
[BB5,BB5 ALGORITHM] size: 18.16 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 06100208153868508BDAFBC2D08108867A6DDCDB
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.781 s
CMT NOR area [000006C0-0001FFFF] erased in 0.062 s
CMT NOR area [00040000-000BFFFF] erased in 2.625 s
CMT NOR area [000C0000-0013FFFF] erased in 0.156 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 22.078 s
CMT NOR area [01380000-0151FFFF] erased in 8.031 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 1 min 59.640 s
Processing PPM file: rm495__06.65.ppm_ua
[BB5,BB5 ALGORITHM] size: 6.52 MB
Bootstrap failed!
RX Buffer: 0000000000F172
same happend with 6300 same problem never finish
Old 01-17-2011, 19:02   #2 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
use mxkey 3.4 rev1.7 becoz 1.8 have bugs
Old 01-17-2011, 19:15   #3 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
only by usb works ok look
Processing MCU file: rm495__07.95.mcusw
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3AEB4A52
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 06100208153868508BDAFBC2D08108867A6DDCDB
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 28C045EF
Verifying communication to device OK.
CMT NOR area [00000000-000006BF] erased in 0.735 s
CMT NOR area [000006C0-0001FFFF] erased in 0.782 s
CMT NOR area [00040000-000BFFFF] erased in 2.968 s
CMT NOR area [000C0000-0013FFFF] erased in 2.641 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 41.578 s
CMT NOR area [01380000-0151FFFF] erased in 9.079 s
Programming completed in 1 min 1.047 s
Processing PPM file: rm495__07.95.ppm_ua
[BB5,BB5 ALGORITHM] size: 6.35 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 44.328 s
Programming completed in 21.734 s
Processing CNT file: rm495__07.95_ISM_008.image_ua_red_movistar_chile_r ed
[BB5,BB5 ALGORITHM] page size: 128 K size: 11.64 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 24.063 s
CMT NOR area [02160000-03FBFFFF] erased in 3 min 14.578 s
Programming completed in 38.609 s
Total time for flashing process(boot+erase+write) was 8 min 38.656 s
Waiting for device boot up ...
Device found: nmwcdc\Nokia 5130 XPressMusic USB Phonet, ID: 2B8D66D
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.95 03-02-10 RM-495 (c) Nokia
Imei plain: 35829303619356-2
Product Code: 0581651
Battery voltage: 3710 mV
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358293036193562
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.16333 seconds with 9 queries
