01-07-2010, 12:33 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | why mxkey stop flashing in midle many time i see that after erasing when start flashing it will stop in midle & set is dead i try 2 times but not sucses same cable smae set 3110c same interfase JAF but mxkey dead set & jaf recover it so i fear before flashing any bb5 & bb5+ set i dont have log because custmer is in hurry so close mxkey & use jaf & flashed set 100% ok i have logs which saved in mxkey folder see here some typicle may be MXKEY team understand it 00000340 |Before flash check: 00000340 |MCU : K:\PROGRA~1\Nokia\Phoenix\Products\3110c\3110_R~1. 21\rm237__07.21.mcusw 00000340 |PPM : K:\PROGRA~1\Nokia\Phoenix\Products\3110c\3110_R~1. 21\rm237__07.21.ppm_mr 00000340 |PPM : 00000340 |UCP : K:\PROGRA~1\Nokia\Phoenix\Products\3110c\3110_R~1. 21\rm237__07.21.image_mr_128 00000340 |UCP : 00000340 |UCP : 00000340 |ADSP : 00000340 |SD\MMC : 00000340 |SD\MMC : 00000340 |AdspCpId : 00000340 |AdspCpId2 : 00000340 |FastFlash : 1 00000340 |SkipUPP : 0 00000340 |SkipErase : 0 00000340 |EraseWhole: 0 00000340 |LangOnly : 0 00000340 |FlsOption : 2 00000340 |Downgrade : 0 00000340 |Sector to Erase: 00000000-000006BF 000006C0-0001FFFF 00020000-0007FFFF 00080000-000DFFFF 00100000-001FFFFF 00200000-0031FFFF 00320000-0105FFFF 01060000-01067FFF 01068000-0107FFFF 00000340 |boot: 0 00000340 |BOOT_ID: C007 00000340 |bootResult: 01 00000340 |ASIC_ID: 010C192101001101 00000340 |Flash Update version v. 8.30.12.34536 for RD&AMS&Production 00000340 |SearchBootCode ->init 00000340 |Path: E:\mobileEx\3.3\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\8.30.12.34536\ 00000340 | ->ASICID match 00000340 | ->BootL String match (BB5) 00000340 |SearchBootCode ->ok 00000340 |Sending bootloader: E:\mobileEx\3.3\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\8.30.12.34536\rap3gv3_2nd.fg 00000340 |Patching RAP bootloader #0 ... 00000340 |Patching RAP bootloader #1 ... 00000340 |Patching RAP bootloader #2 ... 00000340 |BootLoader Ready. 00000340 |SearchAlgorithm ->init 00000340 |RAPIDOv11_algo.fg 00000340 |teflon_sam_nand_xsr_m1.fg 00000340 |h3_sam_nand_xsr.fg 00000340 |h3_sam_nand_gbbm.fg 00000340 |h3_sam_nand_hdd.fg 00000340 |teflon_sam_nand_xsr151_m1.fg 00000340 |RAP3Gv3_algo.fg 00000340 | ->ASICID match 00000340 | ->FlashL String match (BB5 ALGORITHM) 00000340 |-->Algorithm Found. 00000340 |SearchAlgorithm ->ok 00000340 |Sending flashloader: E:\mobileEx\3.3\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\8.30.12.34536\RAP3Gv3_algo_131 .fg 00000340 |Patching RAP flashloader #1 ... 00000340 |Patching RAP flashloader #2 ... 00000340 |Flashloader Ready. 00000340 |Set VPP CMT 00000340 |CMT: Using internal VPP 00000340 |BeginEraseFlash: 2 00000340 |#CMT : 9 sector(s) CMT NOR area #[00000000-000006BF] CMT NOR area #[000006C0-0001FFFF] CMT NOR area #[00020000-0007FFFF] CMT NOR area #[00080000-000DFFFF] CMT NOR area #[00100000-001FFFFF] CMT NOR area #[00200000-0031FFFF] CMT NOR area #[00320000-0105FFFF] CMT NOR area #[01060000-01067FFF] CMT NOR area #[01068000-0107FFFF] 00000340 |#CMT : 9 sector(s) 00000340 |Init Sector CMT 00000340 |ProgrammingStatus: B3 00000340 |ProgrammingStatus: F3 00000340 |Erase complete. 00000340 |Begin flash programming: K:\PROGRA~1\Nokia\Phoenix\Products\3110c\3110_R~1. 21\rm237__07.21.mcusw 00000340 |CMT NOR writing block [00000400], size 0xA0 00000340 |Init Sector CMT 00000340 |CMT NOR writing block [00020000], size 0x280 00000340 |CMT NOR writing block [00020700], size 0x3340 00000340 |CMT NOR writing block [00027480], size 0x400 00000340 |CMT Writing PaPubKeysHash (PAPUBKEYS) 00000340 |Programming failed. |
01-07-2010, 15:10 | #3 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | set is ok working fine but musicplayer canot run so i flash the set in mxkey set is dead after erasing but with jaf that set is flashed ok & working fine same intrefase same set same cable same flash file then why mxkey fail here ???? |
why ustpro stop at 6% when begin flashing u600 | Amar Man | UST Pro II | 0 | 11-10-2009 16:26 |
MXkey - Hang and Stop Alone in many funtions | fusarista | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 08-14-2009 05:40 |
Why multibox stop updates??? | schwantz | Multi-Box | 8 | 02-28-2009 12:11 |
after flash passo c33x stopped %21 try try stopped flashing pls help me!!! | !!!TaaTTalTi!!! | Motorola P2k | 14 | 08-07-2003 12:50 |
C35 V05 stop writing flash in 59% | makona | x1x to x45/x50 | 0 | 11-20-2001 05:02 |
