Old 02-20-2010, 09:45   #1 (permalink)
askaralikp's Avatar
Member: 690456
Sonork: 1587650
Thanks Meter: 117
Red face nokia 5800 start up fild
sir
i have two 5800 hand set that set infoo full ok but startup fild
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1100020DF6740052734123BE2FD688C4E23D4CC3
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61
Original Imei: 35418202738011
Original Product code: 0574328
Bluetooth ID: 00247DB47C07
WLAN ID: 00247DB4CA27
Phone Type: RM-356 (Nokia 5800 XpressMusic)
SW Version: V ICPR72_08w47.1 23-01-09 RM-356 (c) Nokia
Imei plain: 35418202738011-0
Product Code: 0574328
ApeCoreSw: V 11.0.009
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354182027380110
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
plz give one sultion plz
The Following User Says Thank You to askaralikp For This Useful Post:
Old 02-20-2010, 10:20   #2 (permalink)
prince_arsalan's Avatar
Member: 618626
Sonork: 100.1592779
Thanks Meter: 61
First Format File System.............
If Not Solved Then Make Pmm Auth And Write Modified P.M.................
Old 02-20-2010, 10:21   #3 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
manual format your mobile first.........then post result...
Old 02-20-2010, 11:19   #4 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
Originally Posted by askaralikp View Post
sir
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK_TEST passed
Counter: 0/3, 0/10
mobile show shake hand
than shows contact service ????
The Following User Says Thank You to hasnain For This Useful Post:
Old 02-20-2010, 11:26   #5 (permalink)
realtech's Avatar
Member: 1003310
Thanks Meter: 28
Flash ppm then cnt without mcu
Old 02-20-2010, 17:20   #6 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
just format user area if not ok then search in hardware section
Old 02-20-2010, 17:25   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
do selftest and post here
br,
Nokia 3650 Start up failed.Contact retailer! Dido76 WD2 & APE (Symbian Phones) 9 07-21-2013 11:49
n 73 start up fild askaralikp MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-22-2010 19:47
n 73 start up fild prb solved askaralikp MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-22-2010 12:28
Ub Team:Nokia 5800 stuck on Nokia wont start up afer unlocking 00aa Universalbox 13 01-10-2010 15:04
Page generated in 0.18530 seconds with 9 queries
