03-04-2010, 09:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Delhi
Member: 138575 Status: Offline Thanks Meter: 58 | Wi-Fi Problem in E52 after flash I have flashed successfully E52 and updated the Version. IT WAS DONE IN 1.2Mts. Now when I try to go to Wi-Fi, I Get System Error Message. Unable to Use Wi-Fi. Under Phone tests, when I go to WLAN, and Read Info, I get the MAC Address and Permanent MAC Address. I cant do WLAN self test as it is Grayed out. Here is the flashing Log Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm469_032.001_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 96.90 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2CA44C8 RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00000C34 RAP EM1 ID: 00000C30 RAP PUBLIC ID: 1A2002068B60034465C9A37EF9F68FF48C2F9BCD RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Secondary boot loaded. FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: ONENAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Update Server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2CA44C8 [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: 85F252E351E225CAFC4DFBC8041EABD2823E3500 Storing certificate OK. Partitioning.... Partitioning complete Total erase size: 64.00 KB Flash programming ... CMT PAPUBKEYS: 85F252E351E225CAFC4DFBC8041EABD2823E3500 (RAP Certificate 147 v.1) written. Programming completed in 23.829 s Processing file: rm469_032.001_10.01_MENA_A_prd.rofs2.fpsx as PPM [BB5,XSR 1.6] size: 30.55 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Total erase size: 41.75 MB Flash programming ... Programming completed in 7.532 s Processing file: rm469_032.001_C00.01_DEFAULT_prd.rofs3.fpsx as PPM [BB5,XSR 1.6] size: 7.55 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Total erase size: 20.25 MB Flash programming ... Programming completed in 1.859 s Processing file: rm469_032.001_U000.000_prd.uda.fpsx as CNT [BB5,XSR 1.6] size: 752.28 KB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Total erase size: 65.25 MB Flash programming ... Programming completed in 0.578 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia USB Generic, ID: 1B1D349 [ADL] Verifying communication to device OK. Flashing completed in 1 min 14.093 s Phone Type: RM-469 (Nokia E52-1) SW Version: V ICPR82_09w46.4 13-01-10 RM-469 (c) Nokia Imei plain: 3552160XXXXXXX-X Product Code: 0578077 ApeCoreSw: 032.001 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3552160XXXXXXXX Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 1 min 16.984 s How to solve my problem. In self test all TESTS PASSED. HOW TO SOLVE? THANKS, Br jackle123 |
03-09-2010, 08:10 | #5 (permalink) |
Member: 138575 Status: Offline Thanks Meter: 58 | @gbluez Thanks for the reply. The Phone was working well in WiFi before it was updated. It had some time hanging and slow Operations problem. As far as the product code, The Phone has 0578077, But This Was not available, So selected 0578067 and Flashed. Now except WiFi, everything is working Thanks, Br jackle123 |
iphone bluetooth and wi-fi problem | bingo_888 | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-08-2009 17:00 |
WI-FI problem | galant2 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 11-19-2008 16:48 |
problem in c550 after flash | amr_ibrahim | Motorola P2k | 3 | 09-18-2005 02:28 |
problem in c550 after flash | amr_ibrahim | Motorola P2k | 0 | 09-01-2005 11:01 |
Problem in R220 after flashing with ust original | bcnboy | VLSI, Conexant, Skyworks and Old Models | 5 | 02-18-2004 15:02 |
