03-19-2010, 12:00 | #1 (permalink) | |||
Freak Poster Join Date: Oct 2008 Location: MX-KEY is the BEST NOKIA TOOL Age: 42
Member: 888048 Status: Offline Sonork: 123 Thanks Meter: 30 | Mx-Key 1.7 not work with UFS info ok with UFS: Quote:
03-19-2010, 12:26 | #2 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | working ok update nokia module Library version: 1.0.0.7705(18-02-2010), 1.0.0.12656(19-03-2010) and than check again Quote:
03-19-2010, 12:29 | #3 (permalink) |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | If still same than uninstall mxkey than delete folder c:\mobileEx than install again than before signing UPDATE nokia module after that restart app than sign mx app after that post result |
03-19-2010, 12:46 | #5 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | Bro it's problem with crack hwk just conect and update the drivers then update ufs firmware and restart the pc after that sing application and done check it...and post the result.. |
03-19-2010, 12:49 | #6 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1015645 Status: Offline Thanks Meter: 114 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem show this error plz tell me what's problem solution want |
03-19-2010, 13:00 | #9 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Türkiye Age: 48
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | have same problme with ufs interface will not flah any phone Version from phone: 03.92 Version from file: 07.20 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\BB5_3527340xxxxx_BACK .rpl). Flashing completed in 0.391 s Phone Type: RM-146 (Nokia 5300) SW Version: V 03.92 13-10-06 RM-146 (c) Nokia. Imei plain: 3527340xxx Product Code: 0537657 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352734xxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 15.672 s UFS3 SarasSoft disconnected. |
03-19-2010, 13:06 | #11 (permalink) |
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | not work with jaff or ufs i have deleted all files and uninstalled mx then i have lastet installed mx and i have downgrade jaff to b2 from b4 bud same result no flasheing Version from phone: 03.92 Version from file: 07.20 Using device: J.A.F, FW ver: 01.B4 Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\BB5_352734xxxxxxxx_BA CK.rpl). Flashing completed in 1.140 s Phone Type: RM-146 (Nokia 5300) SW Version: V 03.92 13-10-06 RM-146 (c) Nokia. Imei plain: 35273401xxxxxxxx Product Code: 0537657 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352734xxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 23.843 s |
03-19-2010, 13:10 | #13 (permalink) |
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | have you tested with last mobileEx_setup_v3.3_rev1.7_20100318_.exe or you say with old sw my driver is ok brother no problem i work it with jaff and with sarassoft without any problme... only problme with mx b.r senkron24 |
03-19-2010, 13:35 | #14 (permalink) |
Member: 888048 Status: Offline Sonork: 123 Thanks Meter: 30 | JAF box work fine in 1.B2 original but UFS still fail. I remove and install Mx ver 1.6 => its ok with JAF and UFS. I think problem with MX. |
Mx Key PMM Auth not working | UNLOCK PARK ® | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 28 | 07-25-2010 12:49 |
MX-KEY Support Side Not Working | Sahil2007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 05-25-2010 07:27 |
MX KEY RPL server not working | srinibas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 10-31-2009 16:11 |
Mx Key PMM Auth not working | AswanX | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 09-18-2009 22:21 |
k610! key 1,7 not work | ocha_vista | Sony Ericsson Hardware Repair | 3 | 02-06-2009 03:08 |
