Old 02-26-2011, 03:56   #16 (permalink)
alkim's Avatar
Member: 992568
Sonork: kulit
Thanks Meter: 231
i have also notebook and facing same problem my dongle not working in my win7
is there a way to used my dongle in my notebook (model neo notebook)
pls.
Old 02-26-2011, 04:11   #17 (permalink)
SLIPLOCK's Avatar
Member: 86301
Thanks Meter: 107
pls.
after many many test, i never make my mxkey working with win7, but i am nearly sure that if i change the dongle , i go to buy a "vista pkey" and i put my card inside, Mxkey can work on win7... maybe you can try it is not a big money for buy only virgin dongle...
Old 02-26-2011, 07:48   #18 (permalink)
kishore ch's Avatar
Member: 642004
Thanks Meter: 100
@ferdie1969 Learn some english please.
In my comp Mx-key not work with Win7, but with xp mode for Win7 - works fine.
Here is driver for win7
http://rapidshare.com/files/33799560...32bit.rar.html link not working
Old 02-26-2011, 12:05   #19 (permalink)
Member: 94786
Win7 X64 Smart card driver!
I want to use X64 Windows 7 and I did not go, do not drive a smart card ... Could someone give this drive, the original does not work, I tried for several hours ...
I thank you in advance!
Old 02-26-2011, 21:16   #20 (permalink)
Crazy Poster
Member: 82857
Thanks Meter: 8
Works fine for me
I bought the new mx key that came fully activated from my reseller. I am running Windows 7 x64 with it no problem at all. It won't find one of the drivers for sure, but the important one it does. I've unlocked Alcatels and flashed a Nokia 6300 no problems at all with it. No extra drivers required other than in the setup.
Old 02-27-2011, 00:31   #21 (permalink)
sanmyo's Avatar
Member: 1293916
Sonork: 100.16021658
Thanks Meter: 24
mx-key works in windows 7 32...
i'm used in Windows 7 32 and windows Xp sp2 and sp3
Old 04-01-2011, 10:07   #22 (permalink)
SLIPLOCK's Avatar
Member: 86301
Thanks Meter: 107
Hi to all,
i just write here if this can help people!
Since i buy mxkey i try to make in work in Win7 32 bit and it never work for me.
I follow my own advise and buy the "vista pkey"
i remove card from my orange mxkey and i put inside this pkey.
Problem solved
working 100% on win7
WBR
Any luck running on virtual xp mode with windows 7 jmohler Smart-Clip 7 05-31-2018 12:46
ATF and Windows 7 32-bit / Windows 7 64-bit frozenice Advance-Box 24 05-22-2012 09:41
a2dp in windows 7 64bit kadoosh Bluetooth-Software 0 02-03-2010 16:22
Windows 7 / Vista / Xp Sp 3 ... get them all here only DBXBOX Off Topic Zone 0 01-27-2009 17:48
Page generated in 0.17696 seconds with 9 queries
