Crazy Poster
Member: 1166583
Thanks Meter: 24 | Quote:
Originally Posted by gulka Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11866, Date: 26-01-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0A800014E4667D56946D1ECC59D3113A589C3955
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73XXXXXXXXXXXXXXXXXXXXXX
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: Empty
Original Product code: Empty
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 12345610654321-?
Product Code: 0571631
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2009-10-30T08:04:41Z
SW Version: 07.91
Variant Version: 021
ProductProfile: RM495_0571631_07.91_021.spr
Simlock: 0571631_simlock.bin
Imei plain is invalid !!!
SIMLOCK_DATA corrupted! Code: Imei: 354179XXXXXXXX
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0A800014E4667D56946D1XXXXXXXXXXXXXXXXXXXX
ASIC MODE ID: 00
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18XXXXXXXXXXXXXXXXXXXX
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating SIMLOCK...OK
Updating SUPERDONGLE_KEY ...OK
Updating CMLA_KEY...OK
Updating WMDRM_PD...OK
Certificate programmed successfully ! Code: Phone Type: RM-495 (Nokia 5130c-2)
Imei plain: 354179XXXXXXXX-1
Version Info:
MCU SW version: V 07.91 29-10-09 RM-495 (c) Nokia
HW version: 1000
RFIC version: 06540601
DSP version: ICPR72_09w33
LCD version: SEIKO
PPM version: V 07.91 29-10-09 RM-495 (c) Nokia EL
BT MCM version: 2222-302
Retu version: 16
Tahvo version: 22
Content Pack version: Content: el_red V 07.91 29-10-09 RM-495 (c) Nokia
Product Info:
Production serial number: HEC268486
Product code: 0571631
Module code: 0204024
Basic production code: 0567772
Long production SN: 0
Serial Numbers:
IMEI plain: 354179XXXXXXXXX
IMEI spare to net: XXXXXXXXXXXXXXXXX
IMEI SV to net: XXXXXXXXXXXXXXXXX
Other Info:
Model : Nokia 5130c-2 (Classic Phone)
CS type : GSM850/GSM900/GSM1800/GSM1900
BSI: 5,4 KOhm
Imei net: 354179XXXXXXXXX
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF | if only to tell us that mxkey can write rpl on sl3 it's old news if you use the search button you would have known that the FIRST in THE WORLD !! Rebuild SL3 Certificate: date time of post:
10-10-09, 21:07 http://forum.gsmhosting.com/vbb/show...40&postcount=1 and scond post: date and time:
10-12-09, 08:20 http://forum.gsmhosting.com/vbb/show...72&postcount=1 |
