09-25-2010, 11:38 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | x3 rm540 flashing ok but still blink Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm540__03.60.mcusw as MCU [BB5,XSR 1.6] size: 25.93 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1B172927 RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1FF00212A40F0049F5B110F056FB5A2FFD09637E RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update Server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1B172927 [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500303230 (RAP Certificate 193 v.1) written. Programming completed in 35.375 s Processing file: rm540__03.60.ppm_meaa as PPM [BB5,XSR 1.6] size: 6.14 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB Flash programming ... Programming completed in 7.843 s Processing file: rm540__03.60.image_v_0581260_001 as CNT [BB5,XSR 1.6] size: 12.79 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 75.06 MB Flash programming ... Programming completed in 17.125 s [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Pooling for ADL device |
09-25-2010, 11:47 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | coz you're using a very low version... there is a 8.50 firmware... im not so sure if this is the latest but i guess that version will solve your blinking problem... use search button for that version.. |
The Following User Says Thank You to ryumahon For This Useful Post: |
09-25-2010, 12:06 | #4 (permalink) |
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Thank u for your help, it is very faster than normal Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm540__08.50.mcusw as MCU [BB5,XSR 1.6] size: 26.10 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1B172927 RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1FF00212A40F0049F5B110F056FB5A2FFD09637E RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update Server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1B172927 [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) written. Programming completed in 38.531 s Processing file: rm540__08.50.ppm_meac as PPM [BB5,XSR 1.6] size: 5.29 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB Flash programming ... Programming completed in 6.953 s Processing file: rm540__03.60.image_i_0588335_001 as CNT [BB5,XSR 1.6] size: 13.33 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 75.06 MB Flash programming ... Programming completed in 18.063 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia X3 USB Generic, ID: 23BEB69D [ADL] Verifying communication to device OK. Flashing completed in 2 min 0.500 s Phone Type: RM-540 (Nokia X3-00) SW Version: V 08.50 19-07-10 RM-540 (c) Nokia Imei plain: 35340104491873-1 Product Code: 0584186 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353401044918731 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 2 min 5.484 s |
The Following User Says Thank You to MGT SOFTWARE For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
