06-04-2012, 16:40 | #1 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Bulgaria Age: 36
Member: 37668 Status: Offline Thanks Meter: 15 | X7 strange problem RPL backup Erase phone Flash with latest version Repair SD Now MobilEx report that everything is OK - security, SL and so.. Phone enters local mode. When power on to normal mode phone hangs on the blinking white dots ( belle loading ), after 1-2 minutes phone shuts down. Please, help ! Thanks in advance. |
The Following User Says Thank You to IvailoShopov For This Useful Post: |
06-06-2012, 12:09 | #3 (permalink) |
Member: 37668 Status: Offline Thanks Meter: 15 | No result.. tried with different parts. I have erased the phone again and restores but no any result. When I restore erased phone with older version (just for test) 25, the phone doesn't go to local mode and restarts on Nokia logo. With belle phone starts without RPL on contact service. |
06-06-2012, 12:19 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
BR, | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
06-07-2012, 10:26 | #5 (permalink) |
Member: 37668 Status: Offline Thanks Meter: 15 | I re-downloaded the firmware, also flashed another X7 with this firmware and it's working. But the erased X7 doesn't work. I have tried to format the internal memoty, but the same result - blinking dots. |
06-07-2012, 13:44 | #7 (permalink) |
Member: 37668 Status: Offline Thanks Meter: 15 | Here is the bus check: Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: xxxxxxxx Using device: HTI, FW ver: 00.50, SN: xxxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 26A0000831D70344F986184D221374137674A065 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.2.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.2.0 revision: 3.0 size: 0xD44E9 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: A777258432D3E9101D6160DBAC2702FCC602E752 Selected firmware certificate matched. Original Imei: 35625704854533 Original Product code: 059H4C1 Bluetooth ID: 48DCFB734469 SIMLOCK PA identifier: [0] PA_SIMLOC30 Phone type: RM-707 (Nokia X7-00) SW version: V 79_sr1_11w42.5 25-11-11 RM-707 (c) Nokia Imei plain: 35625704854533-5 Product code: 059H4C1 Battery voltage: 4588 mV, current: 0 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356257048545335 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Self test: Code: Phone Type: RM-707 SW version: V 79_sr1_11w42.5 25-11-11 RM-707 (c) Nokia ID Test name Startup Result 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF N passed 3 EAR_DATA_LOOP N passed 12 SIM_CLK_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 90 PWR_KEY N passed 2 CURRENT_CONS N passed 96 HOOKINT N passed 101 BTEMP N passed 23 KELVIN_BATVOLTAGE N passed 19 KELVIN_VIBRA N passed 26 KELVIN_CAPACITOR N passed 29 KELVIN_MISC N !no signal 27 KELVIN_AUDIO N passed 116 KELVIN_XEAR N passed 34 USB_CHARGING N passed 117 DIGIMIC N passed 209 HEADSET_AMPLIFIER N passed 222 LED_CONTROLLER N passed 233 AUDIO_PLL N passed 239 RAM_IF N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N passed 124 CDSP_STROBE N passed 125 CDSP_DIGI_RXTX_IF N passed 83 CDSP_RF_SUPPLY N !failed ! 127 CDSP_PA_ID_PIN N passed 75 CDSP_WCDMA_TX_POWER N passed Very strange problem, the phone was fully working before erase |
06-07-2012, 15:09 | #8 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. your logs seems to be OK, again Erase phone with this attached file, you can follow this link: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ reflash last Anna Firmware, now phone must come in working condition & later update it Belle. BR, ZUBER |
06-08-2012, 17:22 | #9 (permalink) |
Member: 37668 Status: Offline Thanks Meter: 15 | Thank you ! I have tried but can't repair security now: Code: Phone type: RM-707 (Nokia X7-00) SW version: V 92_11w37 14-09-11 RM-707 (c) Nokia ApeCoreSw: 025.007 Imei plain: 35625704854533-5 Product code: 059H4C1 Battery voltage: 4808 mV, current: 0 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Phone version(025.007) outdated, selected version is: 111.30.609 Imei net: 356257048545335 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Latest software release for Nokia X7-00 is Nokia Belle (111.030.0609) |
06-08-2012, 19:51 | #10 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. No problem, go to Service Tab>Click Load from File>go to address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Click RM-707 PM, now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. Just now solve 1 Problematic phone. have a good day. Best Regards, Zuber Chowdhry |
06-12-2012, 12:32 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | You're most welcome, likes to see friends happy. BR, Zuber |
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post: |
07-10-2012, 14:12 | #14 (permalink) |
Member: 37668 Status: Offline Thanks Meter: 15 | 25.7, balkans product code from NaviFirm. If you flash fully erased phone with this version, you must get local mode. Try with Belle if not succeed. |
07-10-2012, 16:52 | #15 (permalink) | |
BR, Zuber Chowdhry | |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
