03-17-2010, 14:17 | #16 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1004257 Status: Offline Sonork: [email protected] Thanks Meter: 14 | Zam zam mobile |
03-17-2010, 14:22 | #18 (permalink) | ||
Insane Poster Join Date: Mar 2010 Location: i dont know :D
Member: 1261157 Status: Offline Thanks Meter: 256 | Quote:
Run HWK Suite or HWK Suite Minor vXX.XX.XXX after initial progress bar, cancel, yes and finish. please next time use search button,problem already posted many times GPG_SUPPORT | ||
03-18-2010, 12:09 | #19 (permalink) |
Freak Poster Join Date: Apr 2007 Location: ZANZIBAR
Member: 496694 Status: Offline Thanks Meter: 95 | i have the same problem.i tried all solution but still same error,ihave change the box all is ok when i connect in software but when i connect my first box in same software it gives an error "none authorised software detected"pls i need solution. |
03-18-2010, 12:41 | #20 (permalink) | |
uninstal old version,install latest,try to update if not,then go to C:\WINDOWS\system32 .remove 2 files hwkkiller.dll and ufsloader.dll luck GPG_SUPPORT | |
03-18-2010, 13:02 | #21 (permalink) |
Junior Member Join Date: Dec 2007
Member: 651877 Status: Offline Thanks Meter: 31 | None authorised copy of software detected" [ANSWERED] None authorised copy of software detected" [ANSWERED] BROTHER COOL NOW . IST YOU REMOVE ALL UFS SETUP .THEN YOU CAN SETUP HWK SUPPORT SUITE V2.9& UPDATE YOUR HWK BOX .AFTER UPDATE HWK BOX SETUP HWK SUITE EXE V2.9 SIZE 84.4 ATER DODE THIS WORK YOUR ALL PROBLEM WILL SOLVE. |
03-20-2010, 16:11 | #22 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Islamabad, Pakistan Age: 42
Member: 48857 Status: Offline Thanks Meter: 31 | I had the same problem but my problem solved in this way First un install all previous versions. Go to regedit->HKEY-LOCAL_MACHINE->Software then right click on SaraSoft and delete whole entery. Reboot the system Install hwk support suite update now install hwk suite. all will be ok........ This is an old post but i am just posting it for further references |
The Following 2 Users Say Thank You to .:::Dr. Cell:::. For This Useful Post: |
03-21-2010, 05:43 | #25 (permalink) |
Junior Member Join Date: Mar 2007 Location: balotra Age: 45
Member: 461885 Status: Offline Thanks Meter: 4 | Hwk == he dont?? We know??? HWK SUPPORT SITE IS OFFLINE HWK == HE DONT?? WE KNOW??? |
The Following User Says Thank You to faridsumro For This Useful Post: |
03-23-2010, 20:21 | #26 (permalink) |
Member: 496694 Status: Offline Thanks Meter: 95 | thanx bro but the problem is not in my sofware coz i have 2 boxs.1 i can connect without any problem but when i connect another box it gives me that error "none authorised copy of software detected" pls i need ur help. |
02-27-2011, 09:00 | #27 (permalink) |
Insane Poster Join Date: Nov 2008 Location: Bomet,Kenya
Member: 900385 Status: Offline Sonork: 1234 Thanks Meter: 10 | Hi my pleasure. o.k i am have tried install the UFS3 box but i got an pop up error ( please Remove HWK Suite, before installing/removing HWK Support Suite) please Help. |
03-31-2011, 14:56 | #28 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Bangladesh
Member: 366214 Status: Offline Sonork: 100.1601104 Thanks Meter: 29 | t-mobile Upgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:3/31/2011 7:49:19 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 93206 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TWISTER -- HWK ID : A1.04-PRO1-BDEC4CC04160000E -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Connection to server failed: Socket Error # 10060 Connection timed out.(A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.) |
05-28-2011, 08:50 | #29 (permalink) | |
Insane Poster Join Date: May 2006 Location: Nairobi, kenya
Member: 276327 Status: Offline Sonork: yahoo/gmail Thanks Meter: 6 | . was in the same boat Quote:
05-28-2011, 13:51 | #30 (permalink) |
Freak Poster Join Date: Dec 2008 Location: nigeria
Member: 917080 Status: Offline Thanks Meter: 13 | Upgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:5/28/2011 1:50:47 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 77034 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-D65B904043600065 -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply plz help me |
