05-30-2011, 10:15 | #31 (permalink) |
Freak Poster Join Date: Dec 2008 Location: nigeria
Member: 917080 Status: Offline Thanks Meter: 13 | ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:5/30/2011 8:38:33 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-D65B904043600065 -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Connection Closed Gracefully. |
06-02-2011, 10:39 | #32 (permalink) |
Insane Poster Join Date: Nov 2008 Location: Bomet,Kenya
Member: 900385 Status: Offline Sonork: 1234 Thanks Meter: 10 | me i hard the same problem and this what i solve the proplem, format my pc and install Kaspersky Anti-Virus then install main hwk suite software |
04-22-2012, 09:02 | #37 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Joined Infinity(dec2018)
Member: 1647864 Status: Offline Thanks Meter: 80 | Hi man i have a simple trick which is just restore your system to the earlier point i have tested it the reason is installation of a software whic is a third party and you must remember that software and also uninstalling that software will not solve the problem just restore or new windows is the best solution it is not a problem of hwk or ufs |
09-08-2013, 17:51 | #38 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1007350 Status: Offline Thanks Meter: 0 | plise App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 273 Serial: Box Boot Failed Bad IX: ABCD Failed: -101 HID Number Corrupted, Try to Use [Update Box] Box: 1 Location: 273 Serial: Box Boot Failed Fatal BOOT Error, Need Repair Box, Contact Distributor |
03-27-2015, 06:14 | #39 (permalink) |
Freak Poster Join Date: Nov 2009 Location: okara pakistan
Member: 1158049 Status: Offline Sonork: i have no sonork id Thanks Meter: 22 | thanxxxxxxxxxxxxxxxxxxxxxxxxxxxx I had the same problem but my problem solved in this way First un install all previous versions. Go to regedit->HKEY-LOCAL_MACHINE->Software then right click on SaraSoft and delete whole entery. Reboot the system Install hwk support suite update now install hwk suite. all will be ok............................... |
