IPmart Cables - http://www.ipmart-cables.com www.ipmart-cables.com |
10-10-2009, 08:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: bestncheap Age: 43
Member: 19785 Status: Offline Thanks Meter: 1,242 | Double USB-A to Single USB-B Pro Cable (With LED) Double USB A to B PRO cable allows to solve problems with low power supply to your devices due USB power overload (500 mA). This great cable got double USB A installed that allows to connect your computer and give extra power to connected device. No more problems with power to your GSM devices with USB connection. Normal USB A TO B cable usually used single USB A connect GSM boxes to computer, will have power not enough problem because single USB port has low power for BOX + SMART CARD + USB HOST + PHONE connected to the box through RJ45. This cable is the solution, because you use double USB ports from 2 computers, you will get double power and 5v voltage. BUY AT HERE |
The Following 5 Users Say Thank You to bestncheap For This Useful Post: |
03-12-2011, 04:59 | #2 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: india Age: 49
Member: 901335 Status: Offline Sonork: 100.1652281 Thanks Meter: 151 | hello sir Quote:
How to change imei w380/w580 just with usb cable? | rushwhq | SETool2 | 3 | 03-30-2010 12:51 |
Double USB A to Mini B Pro Cable (With LED) | bestncheap | IPmart Cables - http://www.ipmart-cables.com | 0 | 10-10-2009 08:57 |
Double USB-A to Single USB-B Pro Cable | IPMART | ipmart WebShop | 0 | 10-08-2009 06:00 |
Cables Unlimited USB-2110 USB 2.0 to IDE and SATA Adapter Cable with Power | IPMART | ipmart WebShop | 0 | 06-25-2009 07:30 |
HOW TO BUILD AN ALCATEL VLExx CABLE WITH ALCATEL OT-*** CABLE ??? | Eagle7 | Alcatel TCL Phones and New Models | 0 | 06-16-2008 07:16 |
