09-15-2009, 15:03 | #1 (permalink) |
Insane Poster Join Date: Mar 2009
Member: 994459 Status: Offline Thanks Meter: 11 | Unexpected Exception:BOX_AUTH_ERROR:20 |
The Following 3 Users Say Thank You to mobispot For This Useful Post: |
09-15-2009, 15:16 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | u have already made a thread in HWK support erea and also u have got anser there than no need another thread one thread is enough http://forum.gsmhosting.com/vbb/show...91#post4847591 |
09-28-2009, 10:03 | #3 (permalink) |
No Life Poster Join Date: Feb 2006 Location: THAILAND-CHINA-INDIA-CANADA
Member: 230831 Status: Offline Sonork: 100.98820 Thanks Meter: 278 | DO NOT, perform this process unless you have Box Auth Error 20, update client reports "use Update Firmware to authorise UFS !" or you are advised to do so. 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your UFS reseller. 8. When you receive xxxxxx.fbi from your UFS reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. Your UFS reseller is the only person who can help with this process, do not ask here in the forum, we will not generate xxxxxx.fbi files for you. NOTES:- 1. the xxxxxx.fbi file sent by your UFS reseller is one time use only. 2. once you have made the xxxxxx.req file, do not perform any other steps on the box, since this will cause the xxxxxx.fbi file to be out of sync br jass |
The Following 2 Users Say Thank You to GSM-FUTURE For This Useful Post: |
11-13-2009, 19:54 | #4 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1160681 Status: Offline Thanks Meter: 1 | hello sir i have purchase a new hwkufs3 box after installation upgration which time i connect box show this message Unexpected Exception:BOX_AUTH_ERROR:20 plz solve this problom thanks |
The Following User Says Thank You to govindkewat For This Useful Post: |
11-13-2009, 20:31 | #5 (permalink) |
No Life Poster Join Date: Jul 2008 Location: H.DALAA Age: 48
Member: 820444 Status: Offline Sonork: 100.1680641 Thanks Meter: 466 | Ask for your reselle to change box dont try to solved when box it new just rebuild to reselle. ------- lahdache |
The Following User Says Thank You to lahdache For This Useful Post: |
11-15-2009, 14:57 | #6 (permalink) | |
Member: 230831 Status: Offline Sonork: 100.98820 Thanks Meter: 278 | hi Quote:
contact ur reseller and ask to provide fbi file and update it ! ur problem will be solved or contact me i,ll help u ! br jass | |
The Following User Says Thank You to GSM-FUTURE For This Useful Post: |
12-21-2009, 15:30 | #8 (permalink) |
Freak Poster Join Date: Nov 2007 Location: matein-3
Member: 628359 Status: Offline Sonork: 100.1583762 Thanks Meter: 39 | UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0 10 Xx.x C0EEC8, , S/n: 137310 Fault in system or missing firmware Please report this error to dealer Selected Device, not Compatible with Software What is this ERROR |
The Following User Says Thank You to blolyxx For This Useful Post: |
06-29-2011, 13:07 | #10 (permalink) |
Freak Poster Join Date: May 2011
Member: 1575359 Status: Offline Thanks Meter: 20 | Unexpected Exception:BOX_AUTH_ERROR:20 plz solve this problom plzzzzzz [email protected] |
09-01-2011, 05:44 | #12 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Lake Mary (Orlando)
Member: 1016569 Status: Offline Thanks Meter: 229 | solution Quote:
don,t worry and no need to ask to help othres because they can,t help any . u send me your req file i,ll generate for your fbi files . if u have team viewer then i,ll fix it soon .. thx | |
The Following User Says Thank You to logicmobile For This Useful Post: |
01-08-2012, 08:13 | #14 (permalink) |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your UFS reseller. 8. When you receive xxxxxx.fbi from your UFS reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. You can mail me req file I will send you .fbi file. |
Big Problem: Unexpected Exception:BOX_AUTH_ERROR:20 | MisterX GSMFREE | Twisterflasher | 34 | 04-18-2016 13:54 |
unexpected exception:BOX_AUTH_ERROR:20 | bannu | HWK | 23 | 12-23-2008 20:46 |
