02-06-2018, 12:57 | #1 (permalink) |
Junior Member Join Date: Jun 2015 Location: JAMAICA
Member: 2408099 Status: Offline Thanks Meter: 4 | I am unable to use my GCPro GCPro SN := GC925B5***** Need assistant on unlocking or unblock my GCPro Box. |
02-23-2018, 03:18 | #4 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2021294 Status: Offline Thanks Meter: 2 | Hello cgpro team I can't upgrad cgpro (Help me sir) Using 1.23 Checking GCPro Card Details... Card verify ok... Card OsVer FFFF GCPro SN:= GC8046D725 GCPRO Activation := CARD IS ACTIVE Checking server connection... GCPro SN GC8046D725 Card OsVer FFFF Server Reply Error := ERR_CARD_Banned Fail to get reply from server stage1. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...23-02-2561- 08-47-29 Using 1.23 -------------------------------------------- Use for >>GCPro_Update59 ReadCGPro Detial GCPro found... Card verify ok... Card OsVer FFFF GCPro SN:= GC8046D725 GCPRO Activation := CARD IS ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...23-02-2561-09-19-31 Log Saved ------------------------ Register Card verify ok... Card OsVer FFFF GCPro SN:= GC8046D725 GCPRO Activation := CARD IS ACTIVE Card is Already Activated... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...23-02-2561-09-21-56 Log Saved ------------------------- Update CGPro Checking GCPro Card Details... Checking server connection... Server Reply Error := ERR_USE_NEW_UPDATE Check internet connection, not able to connect server... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...23-02-2561-09-22-49 Log Saved --------------------- Unbanned CGPro Checking server connection... Server Reply Error := ERR_USE_NEW_UPDATE Check internet connection, not able to connect server... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...23-02-2561-09-24-06 Log Saved NoGood Last edited by spc221; 02-23-2018 at 03:27. |
02-26-2018, 14:32 | #5 (permalink) | |
No Life Poster Join Date: Apr 2015
Member: 2385015 Status: Offline Thanks Meter: 884 | Quote:
Kindly post on GCpro Key Section GCPro Key - GSM-Forum. Our Supporters will help you. Br, GPGTeam | |
