05-26-2009, 16:57 | #1 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | W810 TP repair not work !! Code: 17:56:16 SE Testpoint Full Unlocker v1.05 by Cruiser Team 17:56:16 Initializing... ! 17:56:16 1. Choose the phone model ! 17:56:16 2. If you want to skip Testpoint Stage 1, select the appropriate option (see documentation) ! 17:56:16 3. If you want to perform restore, select GDFS backup file (*.gdfs) ! 17:56:16 4. Connect the data cable and the power supply clips to the phone ! 17:56:16 5. Double-click on cruiser UC-20 test-point cable 17:56:25 Connecting via Cruiser UC-20 Cable (COM7)… 17:56:25 Device driver version: 2.4.6.0 17:56:25 Device driver date: 3-13-2008 17:56:28 Connecting to the baseband CPU... 17:56:29 Entering baseband CPU service mode... 17:56:29 Detected chipset: DB2012 17:56:29 Boot mode: ROM 17:56:31 Sending loader... 17:56:32 Sending loader... E 17:56:32 Error: 0xF1B843F3 E 17:56:32 Error: 0xC790D4B8 E 17:56:32 Error: 0x93DB6CBB E 17:56:32 Failed! ! 17:56:32 Please disconnect battery and cable from the phone! ! 17:56:32 To report errors right-click this window What noa Ultimate unlocker too not work any other sugestion ?? ?? ?? |
05-26-2009, 17:08 | #2 (permalink) | |
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | Quote:
Code: 18:05:52 SE Ultimate Unlocker v3.07 by Cruiser Team 18:05:52 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:05:52 Initializing... ! 18:05:52 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:05:52 2. Choose the phone model ! 18:05:52 3. Select the desired options ! 18:05:52 4. Please connect the phone either via USB while holding 2-5… ! 18:05:52 - or via a serial cable and double-click on it in the device list 18:06:12 Selected phone: W200 18:06:12 Connecting via Generic FTDI Cable (COM11)… 18:06:12 Device driver version: 2.4.6.0 18:06:12 Device driver date: 3-13-2008 18:06:13 Connecting to the baseband CPU... 18:06:18 Entering baseband CPU service mode... 18:06:18 Detected chipset: DB2012 18:06:18 Boot mode: ROM 18:06:18 Sending loader... 18:06:19 IMEI: 35657301877605 18:06:19 OTP CID: 50 18:06:19 Effective CID: 51 18:06:19 Restarting phone … 18:06:21 Sending loader... 18:06:34 Initializing GDFS access... 18:06:34 Writing GDFS… E 18:07:34 Error: 0xE1E2479D E 18:07:34 Error: 0x3173E984 E 18:07:34 Error: 0x4B055A8F E 18:07:34 Error: 0xE9FB48DF E 18:07:34 Error: 0xCC9B40DA E 18:07:34 Error: 0x8F6C03FD E 18:07:35 Error: 0x980B6A88 E 18:07:35 Error: 0x8118A648 E 18:07:35 Error: 0x59AF7680 E 18:07:35 Failed! ! 18:07:35 To report errors right-click this window | |
05-26-2009, 17:11 | #3 (permalink) |
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | When select with ultimate unlocker W810 becosue this model try fix I got this !! Code: 18:10:57 SE Ultimate Unlocker v3.07 by Cruiser Team 18:10:57 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:10:57 Initializing... ! 18:10:57 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:10:57 2. Choose the phone model ! 18:10:57 3. Select the desired options ! 18:10:57 4. Please connect the phone either via USB while holding 2-5… ! 18:10:57 - or via a serial cable and double-click on it in the device list 18:11:06 Selected phone: W810 18:11:06 Connecting via Generic FTDI Cable (COM11)… 18:11:06 Device driver version: 2.4.6.0 18:11:06 Device driver date: 3-13-2008 18:11:07 Connecting to the baseband CPU... 18:11:11 Entering baseband CPU service mode... 18:11:11 Detected chipset: DB2012 18:11:11 Boot mode: ROM E 18:11:12 Error: 0xE1E2479D E 18:11:12 Selected phone type doesn't match the attached phone E 18:11:12 Failed! ! 18:11:12 To report errors right-click this window |
w810 keypad is not working | ankit_sharma | Sony Ericsson Hardware Repair | 0 | 10-01-2009 20:57 |
W810 voluem key not work | alamgarh | Sony Ericsson Hardware Repair | 3 | 05-11-2009 19:19 |
w810 camera button not work | gsm_khorshed | Sony Ericsson Hardware Repair | 1 | 10-27-2008 12:07 |
= Adap TP My501c not work ith Jtag but work with other tool= | bakarioss | SAGEM JTAG UNLOCKER | 5 | 05-25-2007 21:54 |
TP V2 not work after SiemV107 | panafax_gsm | SIEM Service Tools | 1 | 01-12-2006 06:18 |
