Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 11-25-2006, 21:26   #1 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
All Locks is opened but phone is locked on Z530i
hello.
I am some new on cruiser, after search now I can unlock the CID49 w/o probleme, but I have one Z530i after flashing it, all lock is opened but phone don't accept anny sim card (don't test with motorola test card, I lose it )
I think it's GDFS probleme same on the old sony ericsson, but I can't repaire this probleme ?
anny information pls ?
best regards,
JAVA Good.
Old 11-25-2006, 21:52   #2 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
what you see on display when you enter SIM card?
Old 11-25-2006, 22:56   #3 (permalink)
Member: 87533
Thanks Meter: 3
I have the same problem with j220i... When i go into lock menu all are opened, but after power off and then power on the phone don't accept any other sim as only from vodafon towhih he was locked to ... but in lock menu are locks are open
Old 11-25-2006, 23:06   #4 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
how many locks you see, 2 or more ?
Old 11-26-2006, 11:30   #5 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
hello and tks for ur reply, the 4 lock is opened, but phone will be unlocked, I read code after unlock RSA same for the CID49, and read all codes,
it I put relock code it's work for lock it, and If I put unlock code for unlock lock I can ?
but If I use directelly unlock code, don't work (because lock is opened)
tks for all..........
Old 11-26-2006, 11:32   #6 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
there is code I have :
Old 11-26-2006, 12:11   #7 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
after put anny sim card and enter pin number I have this message ( with french) : Erreur configuration. Contactez l'opérateur réseau ou centre service" I think with english is : configuration error, contact the network operator or cervice center
some one can tell what is the probleme pls ?
best regards,
JAVA Good.
Old 11-26-2006, 13:38   #8 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
yes you need flash phone and make customization
Old 11-26-2006, 18:38   #9 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
I just can tell u a BIG TKS, and manny peopel see this post for help and resolv ur probleme, tks again.
best regards,
JAVA Good.
After unlock ub all lock open but Phone start-up failed Contact the retailer mohit_kripalu01 Nokia Base Band 5 ( BB-5 ) 16 08-14-2009 19:10
hellow ub team i unlock 6220c credit is lose but phone is not unlock return credit AYAZ42 Universalbox 0 03-27-2009 16:24
Got Code! But phone is permanently locked Shining Light Phone Unlocking Codes & Maps 0 06-27-2008 10:00
k1/s unlock ok... but phone is locked bb5_secrets Smart-Clip 3 04-21-2008 14:52
I Have T100 Every Thing Is Working But Phone Is Not Connecting Call OSSIE VLSI, Conexant, Skyworks and Old Models 3 05-16-2003 19:52
Page generated in 0.35863 seconds with 10 queries
