Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-24-2009, 19:51   #1 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
Unhappy cruiser s1 server working ?
hi cruiser team
can any one confirm that cruiser S1 unlocking server is working or not..?
i want to unlock but i cant it give me this earror on credit info
here is the log
  00:49:14  SE S1 Flasher & Unlocker v2.05 by Cruiser Team
  00:49:14  Initializing...
! 00:49:14  1. Choose the phone model
! 00:49:14  2. For flashing, select flash files and additional options
! 00:49:14  3. Double-click on the appropriate device (serial cable)
! 00:49:14  - or connect the phone via USB while holding its C button
! 00:49:16  Your card activation ID is: xxxxxxxxxxxx
  00:49:16  Communicating with server…
E 00:49:37  Error: 0x1F41CF97
E 00:49:37  Cannot connect to the server
E 00:49:37  Check server host name and port in the settings
E 00:49:37  Failed!
! 00:49:37  To report errors right-click this window
plz tell when it will come back or wot i do
thanks
regards
Old 06-24-2009, 19:55   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,185
Server Down Try Again Later ............
Old 06-25-2009, 13:57   #3 (permalink)
AliAliGSM's Avatar
Member: 1052732
Sonork: 100.1616786
Thanks Meter: 3,145
Server Down ???????????
Old 06-25-2009, 14:51   #4 (permalink)
Member: 670274
Thanks Meter: 165
Server works well now. There were some outages last week but currently is everything ok.
If you experience problems with connecting to the server, please verify the application settings (60.54.216.58, port 9001), your firewall settings, etc.
(The error "Cannot connect to server" means exactly a problem on a connection layer. Problems with login name/password is diplayed as "Login failed")
GLaDOS
Old 06-25-2009, 16:56   #5 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
still same problem
settings are all ok
  21:54:21  SE S1 Flasher & Unlocker v2.05 by Cruiser Team
  21:54:21  Initializing...
! 21:54:21  1. Choose the phone model
! 21:54:21  2. For flashing, select flash files and additional options
! 21:54:21  3. Double-click on the appropriate device (serial cable)
! 21:54:21  - or connect the phone via USB while holding its C button
! 21:55:48  Your card activation ID is: DD8FB107C53ADA84477EAB402DAB349A-06
  21:55:48  Communicating with server…
E 21:56:09  Error: 0x1F41CF97
E 21:56:09  Cannot connect to the server
E 21:56:09  Check server host name and port in the settings
E 21:56:09  Failed!
! 21:56:09  To report errors right-click this window
Old 06-26-2009, 14:51   #6 (permalink)
Member: 236764
Thanks Meter: 12
i trying unlock w302 but always this error....
  15:48:41  SE S1 Flasher & Unlocker v2.05 by Cruiser Team
  15:48:41  Initializing...
! 15:48:41  1. Choose the phone model
! 15:48:41  2. For flashing, select flash files and additional options
! 15:48:41  3. Double-click on the appropriate device (serial cable)
! 15:48:41  - or connect the phone via USB while holding its C button
  15:49:09  Connecting via SEMC USB Flash Device (USB3)…
  15:49:09  Device driver version: 2.2.0.2
  15:49:09  Device driver date: 12-5-2008
  15:49:10  Connecting to the baseband CPU...
  15:49:10  Entering baseband CPU service mode...
  15:49:10  IMEI: 35896702836639
  15:49:10  Phone type: W302
  15:49:10  CDA info: 1211-0450 R13A
  15:49:10  Phone software: 1207-2402 R1DA003
  15:49:10  Sending loader...
  15:49:14  Reading TA…
  15:49:17  Communicating with server…
  15:49:20  Remainig credit (supreme): 5.7
E 15:49:20  Unknown server problem [256]
E 15:49:20  Error: 0x16D3BA97
E 15:49:20  Error: 0x834ACC0E
E 15:49:20  Error: 0x07F5EFDA
E 15:49:20  Error: 0x51A411A0
E 15:49:20  Error: 0xB8C71F93
E 15:49:20  Error: 0x1850F89E
E 15:49:20  Failed!
! 15:49:20  Please disconnect battery and cable from the phone!
! 15:49:20  To report errors right-click this window
all settings are ok !!
Old 06-26-2009, 15:39   #7 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
finally done
here is the log
  20:35:19  SE S1 Flasher & Unlocker v2.05 by Cruiser Team
  20:35:19  Initializing...
! 20:35:19  1. Choose the phone model
! 20:35:19  2. For flashing, select flash files and additional options
! 20:35:19  3. Double-click on the appropriate device (serial cable)
! 20:35:19  - or connect the phone via USB while holding its C button
  20:36:11  Connecting via SEMC USB Flash Device (USB5)…
  20:36:11  Device driver version: 2.2.0.2
  20:36:11  Device driver date: 12-5-2008
  20:36:11  Connecting to the baseband CPU...
  20:36:11  Entering baseband CPU service mode...
  20:36:11  IMEI: 35653502257390
  20:36:11  Phone type: W302
  20:36:11  CDA info: 1212-2192 R12A
  20:36:11  Phone software: 1207-2375_GENERIC R1AC004
  20:36:11  Sending loader...
  20:36:16  Reading TA…
  20:36:19  Communicating with server…
  20:36:22  Remainig credit (supreme): 2
  20:36:25  Remainig credit (supreme): 1.6
  20:36:25  Searching...
  20:36:25  Unlocking…
  20:36:26  Turning off the phone...
  20:36:26  Done.
! 20:36:26  Please disconnect battery and cable from the phone!
Old 06-27-2009, 12:19   #8 (permalink)
shaheen15's Avatar
Member: 137426
Thanks Meter: 50
  13:18:11  SE S1 Flasher & Unlocker v2.02 by Cruiser Team
  13:18:11  Initializing...
! 13:18:11  1. Choose the phone model
! 13:18:11  2. For flashing, select flash files and additional options
! 13:18:11  3. Double-click on the appropriate device (serial cable)
! 13:18:11  - or connect the phone via USB while holding its C button
! 13:18:14  Your card activation ID is:
  13:18:14  Communicating with server…
E 13:18:35  Error: 0x1F41CF97
E 13:18:35  Cannot connect to the server
E 13:18:35  Check server host name and port in the settings
E 13:18:35  Failed!
! 13:18:35  To report errors right-click this window
server offline???????
Old 06-27-2009, 12:46   #9 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
  17:40:36  SE S1 Flasher & Unlocker v2.05 by Cruiser Team
  17:40:36  Initializing...
! 17:40:36  1. Choose the phone model
! 17:40:36  2. For flashing, select flash files and additional options
! 17:40:36  3. Double-click on the appropriate device (serial cable)
! 17:40:36  - or connect the phone via USB while holding its C button
! 17:40:40  Your card activation ID is: 821740BBB3ED907F18E65AFC5AA7C125-06
  17:40:40  Communicating with server…
E 17:41:01  Error: 0x1F41CF97
E 17:41:01  Cannot connect to the server
E 17:41:01  Check server host name and port in the settings
E 17:41:01  Failed!
! 17:41:01  To report errors right-click this window
again offline
wot is this cruiser team...???
Old 06-27-2009, 13:18   #10 (permalink)
mobile-phone-service's Avatar
Member: 599385
Sonork: 100.1583205
Thanks Meter: 82
Yes is again offline today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 06-27-2009, 13:41   #11 (permalink)
Member: 111730
Thanks Meter: 118
server offline
bad time very bad time cruiser
Old 06-27-2009, 13:41   #12 (permalink)
Member: 889369
Sonork: 100.1638354
Thanks Meter: 321
Server down please help
Old 06-27-2009, 13:43   #13 (permalink)
Member: 111730
Thanks Meter: 118
work again now
tnx and sorry
Cruiser Ultimate unlocker and S1 servers DESBLOKING Cruiser Suite 1 10-30-2009 20:02
Is S1 server working ? jawad8305 Seking Server 4 08-26-2009 15:03
does s1 server works????????? mayreddy Universalbox 4 06-04-2009 19:06
s1 server working or not? 00aa Seking Server 3 05-08-2009 07:18
S1 server not work? ebu mohammed-emin Universalbox 1 02-26-2009 20:21
Page generated in 0.19823 seconds with 9 queries
