Glados help me, and now im passing loader with a new file, but passw failed when I choose unlock Code: 14:53:28 SE S1 Flasher & Unlocker v2.02 by Cruiser Team Code: 14:57:29 SE S1 Flasher & Unlocker v2.02 by Cruiser Team |
Hello, we have just released above mentioned new version of S1 Flasher & Unlocker. CruiserSuite S1 Flasher & Unlocker Version 2.03 [090312]
Enjoy |
problem unlocking k330... Code: 13:01:21 SE S1 Flasher & Unlocker v2.01 by Cruiser Team |
Use SE S1 Flasher & Unlocker V2.03 Quote:
Download it from the links given by Mizar from the post above yours |
problem solved with 2.03 Code: 13:15:36 SE S1 Flasher & Unlocker v2.03 by Cruiser Team |
@ Mizar I have a small problem here! I was using Windows Xp on my old laptop. It is damage, and i'm not using it anymore. Now I have a new laptop runing Vista 64bit and I'm unable to install the drivers for my UC-10 USB Cable. I did download drivers folder from download section and paste to C:\Program files x86\Cruiser Suite\Drivers But still its not installing UC-10 USB Cable for me even if I choose manualy from the folder Drivers\Cruiser Cable UC10. Can the drivers working with Vista 64bit be uploaded for me? Or is there any other method? Thank you! |
Hi Black_Daimond, the issue is caused by Windows Vista x64 itself. There is a known limitation of this operating system - it accepts signed drivers only. Since the only way to properly sign these drivers is revealing our identity, it is not an acceptable option. Therefore, the only way to manage this situation is to change the USB device ID from UC-10 to Generic FTDI. Then you would be able to use generic signed drivers from http://www.ftdichip.com (look for approved CDM drivers) with your instance of Windows Vista x64 OS. On the FTDI home page there is a special utility for editing cable EEPROM content that allows for changing the device ID, among other things. The ID for UC-10 cable is E268, all you need to do is to change it to generic one of 6001 under 32-bit Windows. The vendor ID should remain unchanged (0403). I'll not go into details, this is an advanced operation which involves a risk of putting the cable to unusable condition, therefore you should discuss it with more skilled people around you, if the information provided above does not suffice to you. Best regards, Lead. |
SE S1 Unlocker & Flasher works great now. Code: 12:33:29 SE S1 Flasher & Unlocker v2.03 by Cruiser Team Big thanks to Cruiser team! :) |
To much! Quote:
I have just used a PC with Xp instead. I will study this part about changing Cable ID later. No time for it now. Thank you any way "Lead" |
wonderfull work cruser team nice update Good Luck |
Incompatible files?? Hi people, would someone help me wich files to combine in order to unlock a F305 and have portugue language? It´s from SFR France. See the log: 10:43:35 SE S1 Flasher & Unlocker v2.03 by Cruiser Team 10:43:35 Initializing... ! 10:43:35 1. Choose the phone model ! 10:43:35 2. For flashing, select flash files and additional options ! 10:43:35 3. Double-click on the appropriate device (serial cable) ! 10:43:35 - or connect the phone via USB while holding its C button 11:10:59 Connecting via Generic FTDI Cable (COM6)… 11:10:59 Device driver version: 2.0.0.0 11:10:59 Device driver date: 5-19-2006 ! 11:10:59 Connect the phone now 11:10:59 Connecting to the baseband CPU... 11:11:07 Entering baseband CPU service mode... 11:11:07 IMEI: 35814502117516 11:11:07 Phone type: F305 11:11:08 CDA info: 1218-5915 R2A 11:11:08 Phone software: R1BA017_prg12079123_GENERIC_HS YG 11:11:08 Sending loader... 11:11:17 Reading TA… 11:11:22 About to flash 33 MB of data… 11:11:22 Writing files… E 11:12:45 Error: 0xE1E2479D E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0xDDD701AA E 11:12:45 Error: 0x4835B81D E 11:12:45 Error: 0xE09A592A E 11:12:45 Error: 0xF509DBE3 E 11:12:45 Error: 0xED8715EB E 11:12:45 Error: 0x7C7E4156 E 11:12:45 Error: 0x55D37C39 E 11:12:45 Error: 0x568034E8 E 11:12:45 Incompatible flash file or flashing error 11:12:45 Resetting user code… E 11:12:45 Failed! ! 11:12:45 Please disconnect battery and cable from the phone! ! 11:12:45 To report errors right-click this window Btw, i tried this set: F305_FW_1207-9123_GENERIC_R1BA017_RED.s1fl F305_LP_1207-9163_TELEF-LAM_R1BA017_RED.s1fl F305_Cust_1215-5655_Claro_CL_R6A_RED.s1fl and also this: F305_FW_1207-9123_GENERIC_R1BA017_RED.s1fl F305_LP_1207-9163_TELEF-LAM_R1BA017_RED.s1fl F305_Cust_1214-8315_Claro_BR_R7A_RED.s1fl Tksfor n help. Rgds, |
Simple use latest SE S1 version and choose signed mode, check the unlock box these uses supreme credits. you need supreme credits for unlocking the SE F305 |
