Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 02-20-2009, 21:38   #1 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
Downgrade DB2020 CID80 to normal
How exactly that works? I shall use uc-20 with SE TP Full Unlocker or normal sw? Only via tp? Is UC-20 really needed, or can we use something else?
device is a w880 that has cid80, could not read OTP CID, since phone does not boot. what is needed to do is reset user code.
br
Old 02-21-2009, 02:39   #2 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,065
Use SE Ultimate Unlocker Mate, Settings is this
no lock change - you can just show codes, repair EROM or change certificate to various colors/CIDs
Old 02-21-2009, 03:08   #3 (permalink)
Member: 447548
Thanks Meter: 83
br
CID 80. unusual,, but yes SEMC moving this way toward cid 80, cid 81 and there is another one also.
Old 02-21-2009, 03:14   #4 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,065
This is the advantage of Cruiser they can Downgrade this CIDs-80,81. Other Team still making Solutions.
Old 02-21-2009, 03:24   #5 (permalink)
Member: 447548
Thanks Meter: 83
did you test. If work.. excellent sharing bro
Old 02-21-2009, 03:28   #6 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,065
Havnt seen that phone still Mate, Procedure is in SE Ultimate Unlocker SW.
Old 02-21-2009, 03:31   #7 (permalink)
Member: 447548
Thanks Meter: 83
cool thanks, but would be good to test. I didnt get cid 80 also
Old 02-26-2009, 21:22   #8 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
thanks for all the answers, but no one really answered me... do anyone really knows what I´m talking about and can answer with a simple, direct and short sentence? like "change certificate via tp using uc20", where are cruiser supporters?
"How exactly that works? I shall use uc-20 with SE TP Full Unlocker or normal sw? Only via tp? Is UC-20 really needed, or can we use something else?
device is a w880 that has cid80, could not read OTP CID, since phone does not boot. what is needed to do is reset user code."
as said, phone does not boot via dcu-60 (no matter if erom or usb flash), same thing via box+rj45cable (msg: cid not supported, boot via tp). besides, if procedure have to be done via tp, how come use SE UU???
really? have u think that if wasn´t for cruiser, phone would NOT have cid80, and could be serviced as usual ? having possibility to downgrade is the least they can do.
Old 02-26-2009, 23:40   #9 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
i never see CID80 and CID81 are they realy existing? or is it just a error in phone?
Old 02-27-2009, 21:13   #10 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
www.vazgsm.com.br/db2020_cid80.JPG
www.vazgsm.com.br/db2020_cid80_2.JPG
one thing is new... phone connected using serial cable.
Old 02-27-2009, 21:44   #11 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
what´s the problem, guys?
someone did that CID by Ultimate Unlocker. to revive back, use again Ultimate unlocker and set the cid to 53.
I do not see here anything difficult.
How to Downgrade DB2020 CID53 to CID52 espoir1283 SETool2 18 01-04-2010 14:49
How to Downgrade DB2020 CID53 to CID52?? Panthereitor DreamBox 18 12-02-2008 17:52
DB2020 server back to normal, but not stable welcometrading Universalbox 0 03-18-2007 13:47
Page generated in 0.17653 seconds with 9 queries
