Error on writting CID49 flash file to CID36 K750 phone. Could you please advise, what is the problem? Our customer is flashing his CID36 K750 with latest firmware R1CA021. Flashing as usual gives an error on customization: [ --- Flash Raw File System --- ] Flash file: "K750i_CXC125953_EMEA1_R1CA021_Red49.ck75fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Analysing flash file... Programming flash... Time: 00:03:06 Flash process done. [ --- Customize File System --- ] Sending CS applet... The applet ignored baudrate change request! No response from applet Invalid response |
Did he charge colour to brown before flashing ? If he just unlocked RSA and flashed FW & FS, then he must detach phone unlock RSA again and customise phone. BR Mike |
I guess, he did. I wil check. |
Yes, he did. Code: System diagnostics passed. |
BR krtko |
@Fractalizer Maybe the speed reducing could help, if not Tell to your client to try an older flash group. There are so many in the support. Also give some more info and mainly why he flashes the phone. Was it dead ? Simple Upgrade ? BR Mike |
Older flashes flash without problems. He just wants to put newer firmware to his phone. Phone was working ok. If you recover it via recovery mode and flash after - it works well with CID36 firmwares, but latest stable from them is R1L, which is very old. R1N is beta (brown itself). |
In fact this is a case that should be studied by LEAD. Also tell your client to try R1BC002 flash group, it is Red36 too. Realy strange though BR Mike |
It means that CID36 phones can't be flashed with CID49 flashes. Is this a fact or is it a bug ? We need comments by the Cruiser author. BR Mike |
