Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 08-07-2005, 19:30   #1 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
Question F500i! changed flash ic! did complete "empty board" proc! but still not powering on!
@Mods
I have a F500i which while flahsing RAW FS thru *** stopped at 31%, then i tried flashing with the SETOOL as well but stops at 21/81 %, well then i completely changed a new flash IC and followed the "Empty Board" flash procedure, selected "Fill OTP" and wrote the original imei from back of the phone, selected CID36 and everything went fine! but when i try to power on the phone! sometimes i get a white screen & that slight vibration (common in SE phones) and then nothing. i tried to write GDFS & then unlock as well but still nothing? can u pls help me revive this phone? looking forward.
WBR
ReyTech
Old 08-07-2005, 20:52   #2 (permalink)
Member: 1970
low battery?
br
uniden
Old 08-07-2005, 21:35   #3 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
Originally Posted by uniden
low battery?
br
uniden
@uniden
i try with a different battery as well, then too the same!
WBR
ReyTech.
Old 08-07-2005, 22:04   #4 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Flash ARM again then flash RawFS
Customise the FileSystem
Direct Unlock The Phone (you'll probably have to convert to brown first of all)
See if that helps.
Old 08-08-2005, 17:06   #5 (permalink)
evan_silbert's Avatar
Member: 21920
Thanks Meter: 10
Just a question here... Why would you set an F500i to CID36? Why not CID29?
Old 08-08-2005, 18:53   #6 (permalink)
volmax®'s Avatar
Member: 136609
Thanks Meter: 3
1. select modelly and tick force boot
2. flash Recovery_FKS_Series_Red29.crec
3. reattach phone with select model manally(no force boot)
4. covert to brown and reattch phone
5. flash ARM flash to phone
6. reattach phone again you should boot like normal phone already
7. flash FS and GDFS, type in imei and lock OTP area
8. recalc CRC's
Old 08-08-2005, 20:45   #7 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
@volmax:
Shouldn't step 2 be "Click on 'Repair Certificate in Flash Tab'"? When using Cruiser with "Force RSA Recovery Mode" a recovery certificate is already sent to the phone isn't it? I don't think you then need to flash it in manually.
Or does the Recovery_FKS_Series_Red29.crec work differently to how I think it does?
Old 08-08-2005, 21:46   #8 (permalink)
volmax®'s Avatar
Member: 136609
Thanks Meter: 3
true oso m8
i just write out wat i did recently
Old 12-22-2005, 15:30   #9 (permalink)
Member: 208418
any one know all detail that how to do it one by one step for empty fill ? post here rith detail plz
Old 12-22-2005, 17:22   #10 (permalink)
volmax®'s Avatar
Member: 136609
Thanks Meter: 3
easiest step for me is
1. Force RSA recovery CID=36
2. Repair Certificate
3. Deattach phone
4. Attach phone normal
5. Flash GDFS
6. Flash Main_FS and Raw_FS and decustomize phone
7. Reattach phone
8. Fill OTP imei
9. Direct Unlock
hope this should helps
Old 12-23-2005, 12:09   #11 (permalink)
Member: 208418
thx i ll try it and infom u thx if its working good
Sigmatel s4, Micro Max Q3, ACE H5 , full flashing complete but set not power on nakshatra Chinese Models & Cloned Phones 1 03-29-2010 05:19
Sigmatel s4, Micro Max Q3, ACE H5 , full flashing complete but set not power on nakshatra Infinity-Box 1 03-28-2010 17:47
n70 complete flash but does not power ON gsmsikar Nokia Hardware & Hardware Repair 14 09-08-2008 15:15
k500 successfully flash but still cannot power on kcn Sony Ericsson Hardware Repair 4 07-21-2006 06:41
1100 Rh-18 Can Flashing But Can Not Power On DeltaGSM Nokia Digital Core Technology 4 ( DCT-4 ) 6 07-12-2004 21:33
Page generated in 0.16666 seconds with 9 queries
