Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 12-22-2004, 10:31   #1 (permalink)
livewirecebu's Avatar
Member: 15652
Thanks Meter: 344
Cruiser Installation Problem
Installed my brand new cruiser into 5 computers using the procedure below.
1. Unpack and install CruiserPrepareA_v1.00.rar
2. Restart PC
3. Install required drivers, they should be located
in "C:\Program Files\OS Update and Drivers"
4. Unpack and install CruiserPrepareB_v1.00.rar
5. Restart PC
6. Unpack and install CruiserInstall_v1.00.rar
It gives me this error.
Any help is appreciated.
Old 12-22-2004, 10:55   #2 (permalink)
Member: 67277
Thanks Meter: 5,588
This is a matter of middleware installation. The best would be if you could install the fighter first and than Cruiser exe.
Lead is working on new installer - the INNO was not very good choice.
If that didn't help, go to winnt system32 directory and
regsvr32 iopCOM3.dll
restart the comp and try to run it.
mizar
Old 12-22-2004, 11:29   #3 (permalink)
Member: 15652
Thanks Meter: 344
thank you mizar for the quick reply. But i dont have FIGHTER Installer. I have not used fighter.
regsvr32 iopCOM3.dll tells me
LoadLibrary("iopCOM3.dll") failed - The specified module could not be found.
Old 12-22-2004, 12:39   #4 (permalink)
Member: 7277
Sonork: 100.42158
Thanks Meter: 68
if you want i can give you a copy...the latest installer is 4.33
Old 12-22-2004, 12:42   #5 (permalink)
Member: 15652
Thanks Meter: 344
@sandman
thank you for the offer. I have unlocked several units now.
@mizar
This should not be the case for a 700USD device with problems with installation software.
Regards,
Old 12-22-2004, 12:54   #6 (permalink)
Member: 7277
Sonork: 100.42158
Thanks Meter: 68
@Livewire
No problem..
Old 12-22-2004, 12:57   #7 (permalink)
Member: 67277
Thanks Meter: 5,588
@livewire
Yes that's clear. I told you that we're preparing new installer.
Old 12-23-2004, 19:18   #8 (permalink)
Member: 3671
Thanks Meter: 28
Hi Mizar,
Same problem here. Installing old fighter wont help. I am using new computer. Pls give me information when update is ready. I want to use my new dongle!!!
Old 12-23-2004, 19:29   #9 (permalink)
Member: 73743
Thanks Meter: 2
@alro
if you are a fighter user then i would install it using the fighter setup. I installed cruiser onto a new computer today and i installed older fighter version by following instructions exactly and then i just added the cruiser exe to fighter directory and it worked great for me. very easy.
Old 12-23-2004, 20:11   #10 (permalink)
Bernie's Avatar
Member: 45814
Thanks Meter: 34
I`ve got mine today, only use Cruiser.exe no problem
work perfect.
Bernie
Old 12-24-2004, 06:53   #11 (permalink)
Member: 15652
Thanks Meter: 344
install prepareA, prepareB, installer of cruiser, and installer of fighter in this order. RUn cruiser. it should work this way.
Originally Posted by alro
Hi Mizar,
Old 12-24-2004, 07:34   #12 (permalink)
Member: 99741
I managed to get mine installed this way.
Install fighter preinstall, install fighter, install cruiser.exe into fighter folder.
Run cruiser.
Worked for my pc's & laptop.
HTH.
Old 12-26-2004, 12:19   #13 (permalink)
blood's Avatar
Member: 14440
unlocking_procedure?
any body test the unlocking procedure of k7 series? flashing 100% tsted....
cruiser fighter cable instalation problem bombayteji Nokia Hardware & Hardware Repair 2 09-17-2008 12:31
Installation Problems Of Cruiser P1C1 Cruiser Suite 6 01-28-2006 20:51
Cruiser Cable instalation problem. HELP .... baboom Cruiser Suite 5 06-25-2005 21:51
Cruiser Installation Problem tical Cruiser Suite 2 05-28-2005 21:42
Fighter or Cruiser Installation Problem Cables Cruiser Suite 0 12-26-2004 21:04
Page generated in 0.25004 seconds with 9 queries
