05-17-2009, 05:09 | #1 (permalink) | |
No Life Poster Join Date: Sep 2008
Member: 859702 Status: Offline Sonork: 100.1619060 Thanks Meter: 78 | server conecction problem Quote:
05-17-2009, 08:16 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | please check server Code: 11:12:48 SE Ultimate Unlocker v3.07 by Cruiser Team 11:12:48 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:12:48 Initializing... ! 11:12:48 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:12:48 2. Choose the phone model ! 11:12:48 3. Select the desired options ! 11:12:48 4. Please connect the phone either via USB while holding 2-5… ! 11:12:48 - or via a serial cable and double-click on it in the device list 11:13:11 Selected phone: K530 11:13:11 Connecting via Generic EMP USB Flash Device (USB1)… 11:13:11 Device driver version: 2.2.0.0 11:13:11 Device driver date: 9-18-2008 11:13:12 Connecting to the baseband CPU... 11:13:12 Entering baseband CPU service mode... 11:13:12 Detected chipset: DB2020 11:13:12 Boot mode: ROM 11:13:12 Sending loader... 11:13:13 IMEI: 3579******** 11:13:13 OTP CID: 51 11:13:13 Effective CID: 52 11:13:15 Please reconnect the phone (disconnect, connect while holding 2-5) 11:13:17 Sending loader... 11:13:17 Communicating with server… E 11:13:38 Error: 0x1F41CF97 E 11:13:38 Error: 0x41F19ADB E 11:13:38 Error: 0x51A411A0 E 11:13:38 Error: 0x78E56923 E 11:13:38 Error: 0x5C5AEBE3 E 11:13:38 Error: 0x3D35EAF1 E 11:13:38 Cannot connect to the server E 11:13:38 Failed! ! 11:13:38 To report errors right-click this window |
05-17-2009, 10:11 | #5 (permalink) |
No Life Poster Join Date: Sep 2000
Member: 2054 Status: Offline Thanks Meter: 10 | I have exactly the same problem. But some users can use it, I asked some friends to test. Earlier I used the server w/o problems, and nothing were changed and now only errors. Generally, the current configuration is NOT good, too much users have problems to reach server, product supporters should do stg to solve it instead of talking about crappy search engine and tricky proxies. And I don't think that in Hungary any ports would be blocked... |
05-18-2009, 12:08 | #7 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 670274 Status: Offline Thanks Meter: 165 | There was an unplanned server outage from approx. 05/16 20:10 to 05/17 11:10 UTC. We are sorry for the inconvenience. GLaDOS Cruiser Team |
The Following User Says Thank You to GLaDOS For This Useful Post: |
What happened with Lg private unlocking server ??? | fillon | FuriousGold | 6 | 12-15-2008 17:26 |
What happening with your server | siscel | HWK | 1 | 11-07-2008 10:23 |
What happen with cruiser server | siscel | Cruiser Suite | 13 | 08-09-2008 21:08 |
what happening with griffin server? | TICTAC_M | MT-BOX | 2 | 01-16-2008 09:51 |
whats happening with server | tical | FuriouS II | 1 | 12-07-2004 15:53 |
