05-10-2009, 22:04 | #1 (permalink) |
Junior Member Join Date: May 2009
Member: 1027947 Status: Offline Thanks Meter: 0 | have cruiser 7 do not working with cs ultimate unlocker Code: 19:26:28 SE Ultimate Unlocker v3.07 by Cruiser Team 19:26:28 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:26:28 Initializing... ! 19:26:28 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:26:28 2. Choose the phone model ! 19:26:28 3. Select the desired options ! 19:26:28 4. Please connect the phone either via USB while holding 2-5 ! 19:26:28 - or via a serial cable and double-click on it in the device list 19:26:41 Selected phone: K550 19:26:41 Connecting via Generic FTDI Cable (COM4) 19:26:42 Device driver version: 1.0.2176.0 19:26:42 Device driver date: 12-12-2005 19:26:42 Connecting to the baseband CPU... 19:26:42 Entering baseband CPU service mode... 19:26:42 Detected chipset: DB2020 19:26:42 Boot mode: ROM 19:26:43 Sending loader... 19:26:43 IMEI: 35851601937097 19:26:43 OTP CID: 51 19:26:43 Effective CID: 52 19:26:44 Restarting phone 19:26:46 Sending loader... 19:26:47 Communicating with server ! 19:26:52 News: Your credit consumption policy: Level 1 (Novice) 19:26:53 Remainig credit (supreme): 3.02 19:26:56 Remainig credit (supreme): 2.69 19:26:57 Restarting phone 19:26:59 Sending loader... E 19:27:04 Error: 0xE1E2479D E 19:27:04 Error: 0x07F5EFDA E 19:27:04 Error: 0x916000B5 E 19:27:04 Error: 0x10BE36DC E 19:27:04 Error: 0x59AF7680 E 19:27:04 Failed! ! 19:27:04 To report errors right-click this window Code: 18:31:28 SE Ultimate Unlocker v3.07 by Cruiser Team 18:31:28 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:31:28 Initializing... ! 18:31:28 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:31:28 2. Choose the phone model ! 18:31:28 3. Select the desired options ! 18:31:28 4. Please connect the phone either via USB while holding 2-5 ! 18:31:28 - or via a serial cable and double-click on it in the device list 18:31:37 Selected phone: K550 18:31:37 Connecting via Generic EMP USB Flash Device (USB1) 18:31:37 Device driver version: 1.0.0.8 18:31:37 Device driver date: 3-30-2006 18:31:37 Connecting to the baseband CPU... 18:31:38 Entering baseband CPU service mode... 18:31:38 Detected chipset: DB2020 18:31:38 Boot mode: ROM 18:31:38 Sending loader... 18:31:38 IMEI: 35851601937097 18:31:38 OTP CID: 51 18:31:38 Effective CID: 49 18:31:40 Please reconnect the phone (disconnect, connect while holding 2-5) E 18:31:48 Error: 0xE1E2479D E 18:31:48 Error: 0x4D5EFC5D E 18:31:48 Error: 0x8F9F6E1C E 18:31:48 Error: 0x4B4AFEF3 E 18:31:48 Error: 0x319AC5CC E 18:31:48 Error: 0x624C554E E 18:31:48 Error: 0x753B3327 E 18:31:48 Error: 0x59AF7680 E 18:31:48 Failed! ! 18:31:48 To report errors right-click this window |
05-11-2009, 22:07 | #3 (permalink) |
Member: 1027947 Status: Offline Thanks Meter: 0 | It is the same anser with all the phones wich I tryed with . more than 7 phones 3 of them was ok with out problem I want to check only if my cruiser working but it was the same anser . it seems that it is some problem with the server or credit type or ...???? I had 3 credit wich is not supreme then i bought 5 supreme .I do not now if it is these 3 credits wich cause this problem?????? |
CS Ultimate Unlocker or D Ultimate Unlocker? | dimitron | D-Unlock Suite | 2 | 02-06-2009 00:40 |
CRuiser -06 with CS ultimate unlocker | david05 | D-Unlock Suite | 1 | 12-15-2008 04:50 |
do not work key mc60 after unlock with test point | 123darius | Siemens Hardware Repair Area | 24 | 12-11-2007 17:51 |
T191 Proceeding calls do not work! With a computer not conect! | Extreme | Motorola ODM | 1 | 05-27-2003 22:19 |
