Help plz with u8330 hi, i have strange problem with Lg 8330 and am hoping one of you can help me. i have full flashed phone using cruiser.phone accepts the flash ok but still will not power and i think customer is getting very close to killing me. the strange bit is that when i plug charger into phone phone appears to charge but when i try to power on when charger is inserted keypad lights come on but nothing else no sound no lcd or any other signs of life. any ideas? |
Probably certificate is damaged. Try this: 1. On Primary page select exact phone type LG U8330, Select boot type: Recovery boot, CID=42, use TP. Click Attach to phone btn. You will need testpoint. Open Cruiser help to see where TP is. Just connect the testpoint to GND when asked by Cruiser. Then simply disconnect it when Cruiser prompts you to do so. 2. On Security RSA page click Repair certificate (or Replace certificate with Red42). 3. Primary -> Turn off phone. (don't need TP in next steps) 4. Select boot type: Normal boot. 5. Attach to phone. 6. Flash -> Flash ARM. Select a flash file - "U8330_V20a_Austria_Red42.flp" for example. 7. Turn off phone. If this don't help you, then the problem is more serious - maybe hardware. If the phone is locked use Unlock by patching. br |
Just use Vygis free and flash any working GDFS into your phone (not GDFS in .bif format). Use testpoint. |
THanks |
Yes, Vygis is other tool that may help. On Vygis support site LG section find the "Repair_flashes_for_LG3G" folder and "U81xx GDFS" folder and download files you need and flash the phone using testpoint. |
Hello. My fiend told me to write gdfs,but i dont have this file > and aone have gdfs for 8330 |
hi friends i have also a u8330 for software butt when i connect it i also used full battery butt can't connect also use recovery what i do? please help [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... LG 3G phone detected. Phone CID: 17 Phone color: Brown Flash certificate: A1_LG_AS_CUSTOMER Trying Brown CID17 flash applet... Sending applet prologue... Trying CID16 recovery applet... Terminating threads... All threads terminated. I NEED SOME HELP PLEASE KINDLY? |
where can i get that flashfile ? |
