07-21-2009, 17:32 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 52
Member: 3617 Status: Offline Thanks Meter: 583 | How can i connect SE W350 to unlock with Crusier A1 fast Java unlocker???? i try to put the cable and same time push the button C but always i find phone switch it on and not connect to unlock procedure any trick or something to do can anyone share the unlocking procedure for this stupid phone thx |
07-21-2009, 17:51 | #3 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 583 | the only way to unlock this phone as i see in unlocking software of cruiser is DCU-60 becouse i have also CU20 box cable but is not used so another suggestions????? |
07-22-2009, 10:57 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | There are sometimes some stupid W350 that will hardly connect to software, but you should try and try and the only way to try is: 1. Connect cable to phone without battery inside, 2. While holding down Key 2 on phone insert battery. Otherwise check the phone contacts because Sonyericssons get dirty at the bottom connector. I clean almost every SE that I receive because everyone of them has connect problems, but I just clean them with alcool and cotton buds. BR |
se a1 fast java unlocker freezes on fs help | hollyann | Cruiser Suite | 0 | 02-09-2009 13:58 |
Post Here Successfully unlocked using SE A1 Fast Java unlocker | bhart | Cruiser Suite | 90 | 01-27-2009 22:07 |
w200i successfully unlock by new SE A1 FAST JAVA Unlocker | SanjanMobile | Cruiser Suite | 3 | 01-27-2009 20:22 |
W200i unlock by SE A1 Fast Java Unlocker | [email protected] | Cruiser Suite | 1 | 11-15-2008 13:30 |
can't unlock w200i cid53 [A1 Fast Java Unlocker] | wujor | Cruiser Suite | 3 | 06-29-2008 09:08 |
