How to connect phones with Ultimate Unlocker DB3100, DB3150, DB3200, DB3210, DB3350:
DB2020 (except W880):
DB2020 (W880 only):
DB2012:
For other platforms, this list will be updated soon. Best regards, Lead |
@LEAD Code: 11:03:21 Ultimate Unlocker v1.00 by Cruiser Team |
@chiragp Always use latest version and sometimes try also look inside your log before you'll post it next time. "Login to server failed" always means login to server failed.. |
@main so what to do in case of server failed [should i try after some time ] dear i have used user and pass thanks for fast reply [hope u got my pm] wbr |
@chiragp as usual contact your reseller, ask him to double check what account type you have cruiser/d-unlocker, then be sure you're using matching application se ultimate unlocker/ultimate unlocker |
install lates drivers 2.01 (3-20-2008) |
@chiragp: update ultimate unlocker too. check what mainborad wrote for to be sure. |
special thanks for.................. Quote:
How can i connect the W760? For normal connect is button 5 when press 2+5 is unsupportet boot mode |
try 8 or 2 + * as W880. but the phone looks that C and 2 + 5 should work. |
c and 2+5 works not for this phone i have another unlocked with seking and only button 5 work but i will try different keys |
thank you for the post. |
I try to repair SE W580 with Ultimate Unlocker, I have cruiser card 07 this is the error log. Any idea mates 14:34:12 SE Ultimate Unlocker v1.03 by Cruiser Team 14:34:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 14:34:12 Initializing... ! 14:34:13 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 14:34:13 2. Choose the phone model ! 14:34:13 3. Select the desired options ! 14:34:13 4. Please connect the phone either via USB while holding 2-5… ! 14:34:13 - or via a serial cable and double-click on it in the device list 14:34:23 Selected phone: W580 14:34:23 Connecting via Cruiser UC-20 Cable (COM1)… 14:34:23 Device driver version: 2.4.6.0 14:34:23 Device driver date: 3-13-2008 14:34:24 Connecting to the baseband CPU... 14:34:25 Entering baseband CPU service mode... 14:34:25 Detected chipset: DB2020 14:34:25 Boot mode: ROM 14:34:25 Sending loader... 14:34:26 IMEI: 35714301XXXXXX 14:34:26 Restarting phone … 14:34:28 Sending loader... 14:34:29 Communicating with server… ! 14:34:41 News: You have SE-promo-action #2. Free Ultimate unlocking of all platforms until 2008/10/07 23:59 GMT ! 14:34:42 News: Your credit consumption policy: Level 1 (Novice) (from 2008/10/07 23:59 GMT) 14:34:43 Remainig credit (supreme): 1.00 14:34:48 Remainig credit (supreme): 1.00 14:34:50 Restarting phone … 14:34:52 Sending loader... E 14:36:11 Error: 0x07F5EFDA E 14:36:11 Error: 0x6C729765 E 14:36:11 Error: 0x8CDFAB78 E 14:36:11 Error: 0xFA7863EC E 14:36:11 Error: 0x780BA8B0 E 14:36:12 Error: 0x4C43A214 E 14:36:12 Error: 0x10BE36DC E 14:36:12 Error: 0x59AF7680 E 14:36:12 Failed! ! 14:36:12 Please disconnect battery and cable from the phone! ! 14:36:12 To report errors right-click this window |
No login possible... server error? Code: Code: in the device list What is wrong on your side? |
