Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 09-28-2008, 21:21   #1 (permalink)
Lead's Avatar
Member: 1841
Thanks Meter: 469
Thumbs up How to connect phones with Ultimate Unlocker
DB3100, DB3150, DB3200, DB3210, DB3350:
  • Only DCU-60 and DCU-65 interfaces are supported. Press and hold keys '2' and '5', then connect the DCU-6x cable.
DB2020 (except W880):
  • When using a DCU-6x cable, press and hold keys '2' and '5', then connect the cable.
  • When using a Fighter/UC-10/UC-20 cable (including clones), double-click the cable item in Ultimate Unlocker, then connect the cable to phone.
DB2020 (W880 only):
  • When using a DCU-6x cable, press and hold keys '2' and '*', then connect the cable.
DB2012:
  • Only Fighter/UC-10/UC-20 cables (including their clones) are supported. Double-click the cable item in Ultimate Unlocker, then connect the cable to phone.
For other platforms, this list will be updated soon.
Best regards,
Lead
The Following 55 Users Say Thank You to Lead For This Useful Post:
Old 09-29-2008, 07:37   #2 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@LEAD
  11:03:21  Ultimate Unlocker v1.00 by Cruiser Team
  11:03:21  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  11:03:21  Initializing...
! 11:03:21  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 11:03:21  2. Choose the phone model
! 11:03:21  3. Select the desired options
! 11:03:21  4. Please connect the phone either via USB while holding 2-5…
! 11:03:21  - or via a serial cable and double-click on it in the device list
  11:04:25  Connecting via Generic EMP USB Flash Device (USB7)…
  11:04:25  Device driver version: 2.0.0.4
  11:04:25  Device driver date: 9-12-2007
  11:04:27  Connecting to the baseband CPU...
  11:04:27  Entering baseband CPU service mode...
  11:04:27  Detected chipset: DB2020
  11:04:27  Boot mode: ROM
  11:04:27  Sending loader...
  11:04:27  IMEI: 35243002281002
  11:04:27  Please reconnect the phone (disconnect, connect while holding 2-5)
  11:04:39  Sending loader...
  11:04:39  Communicating with server…
E 11:04:40  Error: 0xE1E2479D
E 11:04:40  Error: 0x4D5EFC5D
E 11:04:40  Error: 0x4A84684E
E 11:04:40  Error: 0xFEC2C417
E 11:04:40  Error: 0xB3A47971
E 11:04:40  Error: 0x41F19ADB
E 11:04:40  Error: 0x51A411A0
E 11:04:40  Error: 0x78E56923
E 11:04:40  Error: 0x5C5AEBE3
E 11:04:40  Error: 0x3D35EAF1
E 11:04:40  Login to server failed
E 11:04:40  Failed!
! 11:04:40  Please disconnect battery and cable from the phone!
! 11:04:40  To report errors right-click this window
The Following User Says Thank You to chiragp For This Useful Post:
Old 09-29-2008, 07:40   #3 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 396
Originally Posted by chiragp View Post
@LEAD
[CODE]
  10:59:23  Ultimate Unlocker v1.00 by Cruiser Team
  10:59:23  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  10:59:23  Initializing...
! 10:59:24  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 10:59:24  2. Choose the phone model
! 10:59:24  3. Select the desired options
! 10:59:24  4. Please connect the phone either via USB while holding 2-5…
! 10:59:24  - or via a serial cable and double-click on it in the device list
  10:59:36  Connecting via Generic EMP USB Flash Device (USB7)…
  10:59:36  Device driver version: 2.0.0.4
  10:59:36  Device driver date: 9-12-2007
  10:59:37  Connecting to the baseband CPU...
  10:59:37  Entering baseband CPU service mode...
  10:59:37  Detected chipset: DB2020
  10:59:37  Boot mode: ROM
  10:59:37  Sending loader...
  10:59:38  IMEI: 35243002281002
  10:59:38  Please reconnect the phone (disconnect, connect while holding 2-5)
  10:59:54  Sending loader...
  10:59:54  Communicating with server…
E 10:59:55  Error: 0xE1E2479D
E 10:59:55  Error: 0x4D5EFC5D
E 10:59:55  Error: 0x4A84684E
E 10:59:55  Error: 0xFEC2C417
E 10:59:55  Error: 0xB3A47971
E 10:59:55  Error: 0x41F19ADB
E 10:59:55  Error: 0x51A411A0
E 10:59:55  Error: 0x78E56923
E 10:59:55  Error: 0x5C5AEBE3
E 10:59:55  Error: 0x3D35EAF1
E 10:59:55  Login to server failed
E 10:59:55  Failed!
! 10:59:56  Please disconnect battery and cable from the phone!
! 10:59:56  To report errors right-click this window
Use v1.01 and sometimes try again, again, it works for me, may be work for you, but dont forget to use port 9001
Old 09-29-2008, 07:47   #4 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
@chiragp
Always use latest version and sometimes try also look inside your log before you'll post it next time. "Login to server failed" always means login to server failed..
The Following User Says Thank You to Mainboard For This Useful Post:
Old 09-29-2008, 07:53   #5 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@main
so what to do in case of server failed [should i try after some time ]
dear i have used user and pass
thanks for fast reply [hope u got my pm]
wbr
Old 09-29-2008, 08:04   #6 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
@chiragp
as usual contact your reseller, ask him to double check what account type you have cruiser/d-unlocker, then be sure you're using matching application se ultimate unlocker/ultimate unlocker
The Following 2 Users Say Thank You to Mainboard For This Useful Post:
Old 09-29-2008, 10:38   #7 (permalink)
piracik's Avatar
Member: 133762
Thanks Meter: 242
@LEAD
E 11:04:40  Failed!
install lates drivers 2.01 (3-20-2008)
Old 09-29-2008, 10:40   #8 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
@chiragp: update ultimate unlocker too. check what mainborad wrote for to be sure.
The Following User Says Thank You to FilipLudvik For This Useful Post:
Old 09-29-2008, 11:38   #9 (permalink)
Gr8SightMan's Avatar
Member: 163076
Thanks Meter: 97
special thanks for..................
DB2020 (W880 only):
Old 10-01-2008, 15:49   #10 (permalink)
Member: 5641
Thanks Meter: 72
How can i connect the W760?
For normal connect is button 5
when press 2+5 is unsupportet boot mode
The Following User Says Thank You to DonaldDuck69 For This Useful Post:
Old 10-01-2008, 15:58   #11 (permalink)
Member: 135110
Thanks Meter: 302
try 8 or 2 + * as W880.
but the phone looks that C and 2 + 5 should work.
Old 10-01-2008, 16:09   #12 (permalink)
Member: 5641
Thanks Meter: 72
c and 2+5 works not for this phone
i have another unlocked with seking and only button 5 work
but i will try different keys
Old 10-02-2008, 18:36   #13 (permalink)
Member: 486980
thank you for the post.
The Following User Says Thank You to kato786 For This Useful Post:
Old 10-03-2008, 03:10   #14 (permalink)
Member: 566229
Thanks Meter: 9
I try to repair SE W580 with Ultimate Unlocker, I have cruiser card 07 this is the error log. Any idea mates
14:34:12 SE Ultimate Unlocker v1.03 by Cruiser Team
14:34:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
14:34:12 Initializing...
! 14:34:13 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 14:34:13 2. Choose the phone model
! 14:34:13 3. Select the desired options
! 14:34:13 4. Please connect the phone either via USB while holding 2-5…
! 14:34:13 - or via a serial cable and double-click on it in the device list
14:34:23 Selected phone: W580
14:34:23 Connecting via Cruiser UC-20 Cable (COM1)…
14:34:23 Device driver version: 2.4.6.0
14:34:23 Device driver date: 3-13-2008
14:34:24 Connecting to the baseband CPU...
14:34:25 Entering baseband CPU service mode...
14:34:25 Detected chipset: DB2020
14:34:25 Boot mode: ROM
14:34:25 Sending loader...
14:34:26 IMEI: 35714301XXXXXX
14:34:26 Restarting phone …
14:34:28 Sending loader...
14:34:29 Communicating with server…
! 14:34:41 News: You have SE-promo-action #2. Free Ultimate unlocking of all platforms until 2008/10/07 23:59 GMT
! 14:34:42 News: Your credit consumption policy: Level 1 (Novice) (from 2008/10/07 23:59 GMT)
14:34:43 Remainig credit (supreme): 1.00
14:34:48 Remainig credit (supreme): 1.00
14:34:50 Restarting phone …
14:34:52 Sending loader...
E 14:36:11 Error: 0x07F5EFDA
E 14:36:11 Error: 0x6C729765
E 14:36:11 Error: 0x8CDFAB78
E 14:36:11 Error: 0xFA7863EC
E 14:36:11 Error: 0x780BA8B0
E 14:36:12 Error: 0x4C43A214
E 14:36:12 Error: 0x10BE36DC
E 14:36:12 Error: 0x59AF7680
E 14:36:12 Failed!
! 14:36:12 Please disconnect battery and cable from the phone!
! 14:36:12 To report errors right-click this window
Old 10-03-2008, 07:37   #15 (permalink)
Member: 151343
Thanks Meter: 3
No login possible... server error?
  08:22:15  Selected phone: K800
  08:22:15  Connecting via Generic EMP USB Flash Device (USB4)…
  08:22:15  Device driver version: 2.1.0.0
  08:22:15  Device driver date: 3-20-2008
  08:22:16  Connecting to the baseband CPU...
  08:22:16  Entering baseband CPU service mode...
  08:22:16  Detected chipset: DB2020
  08:22:16  Boot mode: ROM
  08:22:16  Sending loader...
  08:22:16  IMEI: xxxxxxxxxxxxx
  08:22:16  Please reconnect the phone (disconnect, connect while holding 2-5)
  08:22:31  Sending loader...
  08:22:32  Communicating with server…
E 08:22:33  Error: 0x4A84684E
E 08:22:33  Error: 0xFEC2C417
E 08:22:33  Error: 0xB3A47971
E 08:22:33  Error: 0x41F19ADB
E 08:22:33  Error: 0x51A411A0
E 08:22:33  Error: 0x78E56923
E 08:22:33  Error: 0x5C5AEBE3
E 08:22:33  Error: 0x3D35EAF1
E 08:22:33  Login to server failed
E 08:22:33  Failed!
! 08:22:33  Please disconnect battery and cable from the phone!
! 08:22:33  To report errors right-click this window
   in the device list
  08:38:51  Selected phone: K800
  08:38:51  Connecting via Generic EMP USB Flash Device (USB4)…
  08:38:51  Device driver version: 2.1.0.0
  08:38:51  Device driver date: 3-20-2008
E 08:38:56  Error: 0xD5D8B92F
E 08:38:56  Error: 0x852D9D91
E 08:38:56  Error: 0x4B4AFEF3
E 08:38:56  Error: 0x319AC5CC
E 08:38:56  Failed!
! 08:38:57  Please disconnect battery and cable from the phone!
! 08:38:57  To report errors right-click this window
I´ve got supreme log with cruiser07...
What is wrong on your side?
The Following 2 Users Say Thank You to 2right4 For This Useful Post:
unlock P1i how to connect phone intouchce Seking Server 1 03-28-2009 12:26
How to get free daily ultimate unlock with new Cuiser box ! trungdungg Cruiser Suite 0 10-24-2008 11:30
how can connect phone with usb flashing mode ahmertelecom NSPRO 3 08-01-2008 15:50
How to connect phone got 2 cpu.... desmond2727 PadFinder box 2 07-09-2008 13:33
how to connect 3125 with diego.09 & with which cable manish665 Nokia CDMA 1 04-19-2007 18:51
Page generated in 0.21634 seconds with 9 queries
