Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-26-2005, 15:11   #1 (permalink)
jusluke's Avatar
Member: 26867
Thanks Meter: 3
how to remove phone lock code on k508i
i have a k508i which has phone lock code (probably tried to the nth time and blocked) how can i remove or can i read codes? when i attached phone it says RSA unlock first. im afraid to unlock RSA coz i dont have flash file for this? Can i flash this with k500i software?
thanks for your soonest reply...
Old 01-26-2005, 15:15   #2 (permalink)
Member: 73743
Thanks Meter: 2
Unlock RSA first. Do not worry, nothing bad will happen. Then under the Locks tab, select read codes and you will see the lock code of that phone. Usually it is the last code i think. Have you tried the default code "0000" though lol.
Old 01-26-2005, 15:24   #3 (permalink)
jusluke's Avatar
Member: 26867
Thanks Meter: 3
tried 0000 and got wrong code anyway ill try your solution. sorry im really new in cruiser just got mine working remember you even help me detect the cable. anyway thanks for your quick reply ill post results asap. thanks again
Old 01-26-2005, 15:29   #4 (permalink)
Member: 73743
Thanks Meter: 2
By the way. If you do not want to "read codes" then press "clear phonelock" button and the code will now be 0000.
Old 01-27-2005, 10:42   #5 (permalink)
isaackenny's Avatar
Member: 9194
Thanks Meter: 3
Use Cruiser 1.00 to unlocked RSA when defeated use go to locks READ CODES u will have all the necessary code, After code readed remember to Flash MAIN ARM if not the phone is not power on . . Only Cruiser 2.20b can unlock RSA the phone can still on .
@gbrooks3
NO "clear phonelock" option in all Cruiser current released
How to remove phone lock code G810??? jham UST Pro II 19 10-04-2009 12:11
How to remove phone lock code on SE K850i NKO Sony Ericsson 3 04-10-2009 22:09
How to remove phone lock code on k770 sniper007 SETool2 1 02-10-2009 15:12
Is possible to remove Phone Lock Code on DB-2020 phone without Unlock RSA? Jazz Cruiser Suite 6 09-18-2008 01:01
How to remove phone lock code on x70? sutiee Panasonic 9 04-21-2005 08:38
Page generated in 0.14861 seconds with 9 queries
