Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 08-03-2009, 14:49   #1 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 471
J132 can't unlcok with S1 unlcoker 2.05 can you fix this ??
Like in topic I try unlock and all time this error
  15:45:34  SE S1 Flasher & Unlocker v2.05 by Cruiser Team
  15:45:34  Initializing...
! 15:45:34  1. Choose the phone model
! 15:45:34  2. For flashing, select flash files and additional options
! 15:45:34  3. Double-click on the appropriate device (serial cable)
! 15:45:34  - or connect the phone via USB while holding its C button
  15:45:52  Connecting via Generic FTDI Cable (COM3)…
  15:45:52  Device driver version: 2.4.6.0
  15:45:52  Device driver date: 3-13-2008
! 15:45:52  Connect the phone now
  15:45:52  Connecting to the baseband CPU...
  15:46:01  Entering baseband CPU service mode...
  15:46:02  IMEI: 35710702525869
  15:46:02  Phone type: J132
  15:46:03  CDA info: 1218-5985 R5A
  15:46:03  Phone software: 1211-2311 R1AA029
  15:46:03  Sending loader...
  15:46:23  Reading TA…
E 15:46:24  Error: 0xE1E2479D
E 15:46:24  Error: 0x95E7FFF7
E 15:46:24  Error: 0xE09A592A
E 15:46:24  Error: 0xB40A84A8
E 15:46:24  Error: 0xB64D3C75
E 15:46:24  Error: 0xDAA2B4A2
E 15:46:24  Error: 0x24F71A5C
E 15:46:24  Error: 0x8D7688D1
E 15:46:24  Failed!
! 15:46:24  Please disconnect battery and cable from the phone!
! 15:46:24  To report errors right-click this window
Can you fix this ?? ?? ??
I got credits 15.53 and I use signed mode and not work this is new processor then need signed mode but not work with cruiser when you fix this ??
Old 08-03-2009, 16:51   #2 (permalink)
Member: 747913
Thanks Meter: 2
Just select the flash files, and do it again....
best regards
Old 08-04-2009, 12:18   #3 (permalink)
Member: 432404
Thanks Meter: 7
This is the cable Prob use RJ45 J132 cable.
Old 08-06-2009, 09:01   #4 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
J132 unlocked successfully on this version
check ur cable or post screen shot here
Can't unlock S8300 with 5.8.1 can you fix this ?? wgmmmx SPT BOX 5 07-10-2009 11:41
1650 ascii 11 can't work with UB with other box ok can you fix this ?? wgmmmx Universalbox 4 10-22-2008 16:00
Z400 can't unlock with 3.08 can you fix this ? wgmmmx Ultimate-Sam 1 07-18-2008 18:03
6280 after flash with 3.60 no galery Can you fix this ?? ?? ?? wgmmmx Universalbox 12 06-27-2006 14:53
Page generated in 0.13811 seconds with 9 queries
