Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-08-2005, 15:30   #1 (permalink)
Member: 38888
Thanks Meter: 52
J200i problem !!!!!
HI all! Cruiser flash the phone successful, but after that in the place of the letters there are arrows, squares, and another simbols. I think that is wrong flash type. I tried to flash it with any flash type R1B, and R1C, but stil the same. May be it is R2C, or R2B, but it is missed in the support area . Have anybothy solution for that?
Old 06-08-2005, 15:35   #2 (permalink)
Member: 150666
Yes, i also have same problem here, i thought maybe the firmware have some problem!
hope some one can help here!
BR.,
Growell Team
Old 06-08-2005, 15:56   #3 (permalink)
Member: 43368
Sonork: 100.1584138
Thanks Meter: 200
Same problem i flash the phone successful (type R1B, and R1C), but can't power on.
Old 06-08-2005, 16:11   #4 (permalink)
volmax®'s Avatar
Member: 136609
Thanks Meter: 3
u all can try flash this file into your phone
'J200i_World_Generic_NOT_TESTED.ARM'
then to Cruiser team
pls check this file
'J200c_China_CXC125975_R1C.ARM'
coz after i flash to J200 phone dun have chinese wording
and i use EMMA II to detect and it show english version not chinese.
Old 06-08-2005, 20:17   #5 (permalink)
Lead's Avatar
Member: 1841
Thanks Meter: 469
R2B flashes will appear in the support area soon. R2 firmwares should not be downgraded to R1.
Old 06-09-2005, 07:09   #6 (permalink)
Member: 38888
Thanks Meter: 52
10x Lead! I'll be happy!
Old 06-29-2005, 19:23   #7 (permalink)
Member: 8594
Thanks Meter: 13
@Lead:
Can you please upload R2B flashes to support area? I need them too... Thank you!
EH
Old 06-30-2005, 06:53   #8 (permalink)
Member: 8594
Thanks Meter: 13
I noticed another problem with J200i: the phone doesn't always power on after any operation with fighter cables, resulting in 'dead' phone. Solution is to use simple serial cable and unlock it again. Now phone will power on and after shutting it down normally everything works fine.
EH
Old 06-30-2005, 06:57   #9 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
EH
These phones are based on the Z200, the Z200 has the same problem where sometimes you end up with a "dead" phone. The solution is to power the phone off if it turns on, rather than just pull the cable out.
There's a good post by evan_silbert about Z200 unlocking, the same will apply to the J200i
Old 06-30-2005, 07:42   #10 (permalink)
Member: 8594
Thanks Meter: 13
Yes, I am aware of that. But with fighter cable the phone doesn't power on automatiacally after unlocking, so I can't power it off and then the phone is 'dead'. With a simple serial cable it does power on: after power off it is alive again.
Just thought I would post it here, because I hear more ppl having problems with 'dead' j200. Using a simple serial cable instead of fighter cable can bring it back to live for some ppl...
EH
Old 07-02-2005, 15:40   #11 (permalink)
Member: 132576
Lead:
Old 07-02-2005, 17:43   #12 (permalink)
djawir's Avatar
Member: 39539
Thanks Meter: 65
i have j200i with blank lcd after flash its work good but after 1 hour its back with lcd blank again. then try reflash phone again but still lcd blank
Old 07-07-2005, 11:50   #13 (permalink)
Member: 98342
Sonork: 1641338
Thanks Meter: 19
same problem with my j200i phone can power on but blank lcd, any solution for that
Old 07-29-2005, 16:37   #14 (permalink)
Kashif Khan's Avatar
Member: 88016
Thanks Meter: 320
just reflash with UFS and try it
Uncheck Exit Boot
Select Appropriate Con File
Select Appropriate Fix File
Select Appropriate Cust File
Flash MCU + Cust
Then Select Z200 as a Model & Do Unlock & Then Init Secblk .
__________________________________________________ __
i use this method its working 100%
Kashif Khan
Old 10-12-2005, 22:33   #15 (permalink)
Member: 78018
Thanks Meter: 4
that model of repairing in my case do not work, i have j 200 who is f***d up with virgin cust file before about 2 months. I by it. I was read backup from phone before start unlocking, it was my 1rst.
Try-ed with converted flash bin2ufs ->phone power up only with autoignition serial cable when remake crcs, give screen charging, when pres power Death
Try-ed with all flashes from ufsx support area -> same sh*t
Try-ed with cruiser -> nothing hapen's
only one solution now is to try with zuleas USB-Smart i will post results but first i have to find j200 arm flash
that's my eXpiriance...
acount id problem.help uregent plz [SOLVED] dani2080 PolarBox 3 2 03-29-2010 12:46
J200i Restrat Problem Ja\/\/aD Sony Ericsson 30 05-28-2006 00:28
j200i problem later flash erayturkoglu MT-BOX 1 05-18-2006 15:08
J200i Problem in Unlocking fateh76dz FuriouS II 8 08-17-2005 21:21
j200i charging problem sanjeev_in Sony Ericsson Hardware Repair 4 04-01-2005 12:42
Page generated in 0.23902 seconds with 9 queries
