Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 04-03-2009, 16:39   #1 (permalink)
Member: 549796
Thanks Meter: 56
W810i, CID50 UNLOCK FAILED.
W810i, CID50.
1st my phone was dead, I flash the phone by SEtool3 flash ok but Unlock failed . SOW "Insert correct Sim card" With test sim.
Then I flash the phone By cruiser 2files And Customizes FS,
2nd, Itrying "SE Ultimate Unlocker" Brown,CID49 . now phone LOCK .
Plssssssssssss help me.
MOBILE PLUS
  14:32:33  SE Ultimate Unlocker v3.07 by Cruiser Team
  14:32:33  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  14:32:33  Initializing...
! 14:32:33  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 14:32:33  2. Choose the phone model
! 14:32:33  3. Select the desired options
! 14:32:33  4. Please connect the phone either via USB while holding 2-5…
! 14:32:33  - or via a serial cable and double-click on it in the device list
  14:32:46  Selected phone: W810
  14:32:47  Connecting via SEMC USB Flash Device (USB1)…
  14:32:47  Device driver version: 2.2.0.0
  14:32:47  Device driver date: 9-18-2008
  14:32:47  Connecting to the baseband CPU...
  14:32:47  Entering baseband CPU service mode...
  14:32:48  Detected chipset: DB2012
  14:32:48  Boot mode: EROM
  14:32:48  EROM version: R3A024      prgCXC1251050_EROM_DB201X_SIBLEY_FOTA_FLAFLA_SEMCUSB
E 14:32:48  Error: 0x889C690F
E 14:32:48  Unsupported boot mode
! 14:32:48  Please boot via ROM
E 14:32:48  Failed!
! 14:32:48  To report errors right-click this window
Old 04-03-2009, 16:47   #2 (permalink)
badillo's Avatar
Member: 57203
Thanks Meter: 227
Originally Posted by Mobile_plus View Post
W810i, CID50.
MOBILE PLUS
E 14:32:48  Failed!
try to unlock again using cruiser cable instead usb no need more credits
The Following User Says Thank You to badillo For This Useful Post:
Old 04-03-2009, 16:50   #3 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
Post
W810i, CID50.
MOBILE PLUS
E 14:32:48  Failed!
yes sir you need to updet the firmware than tri to unlock if not working than contacts : [email protected]
The Following User Says Thank You to FEATURE GSM™ For This Useful Post:
Old 04-03-2009, 18:47   #4 (permalink)
Member: 549796
Thanks Meter: 56
I am trying and trying
but problem is same
plsssss help me
The Following User Says Thank You to Mobile_plus For This Useful Post:
Old 04-04-2009, 11:01   #5 (permalink)
Member: 549796
Thanks Meter: 56
Thanks ,
When i choose model W200, then My phone unlock.
Thanks All.
W810i CID50 5 Locks closed and many other models unlock/repair successfull !!! mughalG DreamBox 18 07-18-2008 15:39
w810i cid50 unlock problem? patric FuriousGold 4 02-20-2008 11:13
Error when unlocking w810i cid50, help! solution4mobile Universalbox 4 10-30-2007 09:51
W810i cid50 flash/unlock problem judas Cruiser Suite 15 10-13-2007 00:15
unlock W810i cid50 afo Cruiser Suite 5 08-23-2007 02:13
Page generated in 0.22830 seconds with 9 queries
