Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-13-2010, 22:22   #1 (permalink)
Member: 118601
Thanks Meter: 200
K320i 5 LOCK CLOSE HOW TO UNLOCK?
i have here K320i with 5 lock close i read somewhere in the forum few months that it can be unlock by cruiser but now can't find it again in forum...so please how unlock it? with credit and ultimate unlocker or what other? let me know please.
The Following User Says Thank You to denard For This Useful Post:
Old 01-14-2010, 00:52   #2 (permalink)
Member: 84740
Thanks Meter: 5
1- Use the SE A1 Fast Java Unlocker.
2- Choose the phone model.
3- connect the phone while holding its C button…
4- see what happen...
( u need test card for unlocking )
The Following User Says Thank You to Senapse For This Useful Post:
Old 01-14-2010, 00:57   #3 (permalink)
Aishur's Avatar
Member: 28188
Thanks Meter: 579
You need to use server ( SeUltimateUnlocker) for that
Old 01-14-2010, 07:02   #4 (permalink)
Member: 118601
Thanks Meter: 200
man did you see such phone before? with even Test card, it only show "insert sim card correct"
so forget about that solution my dear. i'm going to try with ultimate unlocker
Old 01-14-2010, 07:04   #5 (permalink)
Registered User
Member: 100376
Sonork: 100.1591842
Thanks Meter: 150
if all five locks r closed u need to unlock with server it will not accept test card if all locks r closed
Old 01-14-2010, 13:18   #6 (permalink)
Member: 118601
Thanks Meter: 200
unlock done with server and credit
  13:04:05  SE Ultimate Unlocker v5.04 by Cruiser Team
  13:04:05  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  13:04:05  Initializing...
! 13:04:05  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 13:04:05  2. Choose the phone model
! 13:04:05  3. Select the desired options
! 13:04:05  4. Please connect the phone either via USB while holding 2-5…
! 13:04:05  - or via a serial cable and double-click on it in the device list
  13:04:29  Selected phone: K320
  13:04:29  Connecting via Generic FTDI Cable (COM3)…
  13:04:29  Device driver version: 1.0.2176.0
  13:04:29  Device driver date: 12-12-2005
  13:04:30  Connecting to the baseband CPU...
  13:04:30  Entering baseband CPU service mode...
  13:04:30  Detected chipset: DB2012
  13:04:30  Boot mode: ROM
  13:04:31  Sending loader...
  13:04:31  IMEI: 35165002329868
  13:04:31  OTP CID: 50
  13:04:32  Effective CID: 50
  13:04:32  Restarting phone …
  13:04:34  Sending loader...
  13:04:35  Communicating with server…
! 13:04:54  News: Happy Hour Promotion - FREE S1 unlock today until 13:00 UTC!
! 13:04:57  News: Unlock for free if you have at least 1 Supreme Credit.
! 13:05:01  News: Your consumption level is: Level 2 (Junior)
  13:05:03  Remainig credit (supreme): 1.52
  13:05:16  Remainig credit (supreme): 1.27
  13:05:17  Restarting phone …
  13:05:20  Sending loader...
  13:05:24  Code NCK for relock: 3847514918890163
  13:05:24  Code NSCK for relock: 0763300374106811
  13:05:24  Code SPCK for relock: 8648000546832002
  13:05:24  Code CCK for relock: 0437447877245390
  13:05:24  Code PCK for relock: 2280207724195929
  13:05:24  Code ESLCK for relock: 7477850847892257
  13:05:24  Code NCK for unlock: 1277039522363128
  13:05:24  Code NSCK for unlock: 0872521213510151
  13:05:25  Code SPCK for unlock: 3143882189071516
  13:05:25  Code CCK for unlock: 8178502370242472
  13:05:25  Code PCK for unlock: 0004908136755747
  13:05:25  Code ESLCK for unlock: 6326975431502012
  13:05:25  To enter a code, type < * * < on the phone with SIM-card inserted
  13:05:25  Writing flash…
  13:05:27  Turning off the phone...
  13:05:29  Done.
Old 01-16-2010, 10:23   #7 (permalink)
Member: 782390
Sonork: oshiu
Thanks Meter: 57
yes even five locks will not accept test card
only supreme credit will do
Old 01-16-2010, 10:36   #8 (permalink)
Member: 411207
Thanks Meter: 164
test card not accepted use universal sim tested
Old 01-16-2010, 12:25   #9 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,745
read the Whole Thread Before posting Rubbish,
5 locks Requires Full unlock,
it dont matter what SIM you Try, Gold/Super/Pink,, IT WONT WORK,
it has to BE full unlock.
Old 03-10-2010, 13:46   #10 (permalink)
Member: 118601
Thanks Meter: 200
i have another problem now with this phone. after unlock few weeks ago, now customer return with phone dead! i want to flash it but can't. it boot normaly but when charge flash( main firmware or raw FS) it only fail said error script....
how to flash cid 50? i try both RJ45 and usb but the same result or error
  13:34:00  SE A1 Java Unlocker v1.10 by Cruiser Team
  13:34:00  Initializing...
! 13:34:00  1. Choose the phone model
! 13:34:00  2. Select main firmware flash file (*.a1sw)
! 13:34:00  3. Select raw FS flash file (*.a1fs)
! 13:34:00  4. Please connect the phone while holding its C button…
  13:37:36  Connecting via SEMC USB Flash Device (USB6)…
  13:37:36  Device driver version: 2.1.0.0
  13:37:36  Device driver date: 3-20-2008
  13:37:36  Connecting to the baseband CPU...
  13:37:36  Entering baseband CPU service mode...
  13:37:36  Detected chipset: DB2012
  13:37:36  Boot mode: EROM
  13:37:36  EROM version: R3A021      prgCXC1250692_EROM_DB2010_GENERIC_FOTA_FLAFLA_SIBLEY_SEMCUSB
  13:37:36  Initializing flash files...
  13:37:41  Sending loader...
  13:37:41  About to flash 28 MB of data…
E 13:37:41  Error: 0x5593BD55
E 13:37:41  Error: 0x2701BE08
E 13:37:41  Error: 0xA8A269DB
E 13:37:41  Error: 0xB63595F9
E 13:37:41  Cable disconnect detected
E 13:37:41  Failed!
! 13:37:41  Please disconnect battery and cable from the phone!
! 13:37:41  To report errors right-click this window
with RJ45 Cable and cruiser 13.21
System diagnostics passed.
Version 13.21 ready!
[ --- Attach to Phone --- ]
Connecting via Interceptor USB Cable...
Powering on the phone...
Baseband chip ID: 0x8040
Protocol version: 3.1
Baudrate = 460800Bd
Booting via ROM...
Sony Ericsson phone detected.
Phone CID: 53
Phone color: Red
Flash certificate: A1_DB2010_53_RED
Trying Red CID53 flash applet...
Sending applet prologue...
Sending applet body...
Terminating threads...
All threads terminated.
Baudrate = 460800Bd
Booting via ROM...
Phone CID: 53
Phone color: Red
[ --- Detach Phone --- ]
Baudrate = 460800Bd
Booting via ROM...
Phone CID: 53
Phone color: Red
Time spent entering bootstrap: 1s
Initializing phone hardware...
Applet ID: 071219 1257 ESG_DB2012_FLASHLOADER_...
Flash manufacturer: Intel
Flash ID: 0x897E
OTP Security Level: 1 (Retail)
OTP CID: 50
Phone hardware initialized OK
[ --- Flash Raw File System --- ]
Flash file: "K320i_CXC1250690_France_R4EA031_Red50.ck32fs"
Waiting for flash file to load...
Preparing to program flash...
Defeating RSA protection...
Script error: Unspecified [13.21.44]
Old 03-11-2010, 15:06   #11 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
Phone CID: 53
Phone color: Red
And you are trying to flash Red50?
Old 03-11-2010, 15:20   #12 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
use the curiser ultimate unlocker with this settings:
1.) model: K320i
2.) No lock change
3.) checkbox 1 checked
4.) checkbox 2 not checked
5.) CID: 50
with rj45 cable*
make do job!
now do no other steps..
now just flash it with cid50 flashfiles and all is back again.
br.
hari
Old 03-11-2010, 16:19   #13 (permalink)
Member: 1257398
Thanks Meter: 2
setool now free unlocked 5locks . cruiser updateeeeeeeeeeeeeeeeee plz for free unlock.
Old 03-11-2010, 17:20   #14 (permalink)
Member: 57803
Thanks Meter: 99
You have been a member for less than two weeks and already your asking for something free.
Thats got to be some sort of record.
Old 03-11-2010, 17:37   #15 (permalink)
Member: 118601
Thanks Meter: 200
1.) model: K320i
2.) No lock change
5.) CID: 50
with rj45 cable*
make do job!
br.
hari
please sir are you sure it is not going to consume me credit log from server?
w810 5 lock closed how to unlock with ub ikram tabassum1 Universalbox 3 02-13-2010 13:13
sony ericsson k320 5 lock close how to unlock cruiser m_tahir1 Cruiser Suite 1 02-05-2010 22:38
SE K320i 5 LOCKS CLOSED. AbdulKadir Universalbox 7 07-01-2009 09:08
SE K810i 5 Locks Close Not CSCA Unlock Credit Loss rajinder1978 Universalbox 2 04-30-2009 19:51
K320i 5 LOCKS CLOSED denard Cruiser Suite 5 08-10-2008 03:19
Page generated in 0.22912 seconds with 9 queries
