K800, K610, W850 Starting Problem Hi ! I've got 3 phones K800,K610,W850 the thing is that as soon as i press power button phones come on with White screen and Vibrate aswell but after tht nothing happens and gets stuck on white screen. Any Good solution ???????? Awaiting for ur Expert Solution ~~~~ Thnx |
i had a w850 with white screen and vibrating. After fullflash and finalizing everything was working well for me.. greets sven |
ihad the same brp with K610 cid 51 it shows configration error so i flashed twice cid 51 different flashes from support and finalise it towice lost 2 credits after the first time lcd white vibrating continously the same after the 2 flash IC's glode ????????? |
tray to upgrade cid to CID52 and flash with cid52 br |
same happened to me in k510, have a solution for me?? |
i to same after trying many differnet flashing i upgrade it to cid52 and flashed with cod52 flash and still the same white lcd with vibration any real solution for this |
i think may people have same problem i have w850 when u turn on vibret n after whie screen comes and go comes n go.no body have solution. i flahe many timebut stil same i even replaced flex cable but no result. |
i try use to use cruiser for my k600.. still nothing happen.. |
Please follow the Cruiser instructions carefully. Also Check cable. |
if phone is not water damage so this is 100% soft problem just change flash files if water damage phone is short |
well try now to follow this as -------------------------------------------------------------------------------- I am flashing/unlocking alot whithout a prob. 1. attach 2. check for repair eerom (even if it is new no prob. just do it as a procedure) 3. attach 4. unlock rsa 5. flash the whole ARM ( forget about restore ) 6. direct unlock 7. flash the FS 8. customize 9. shut down file system |
Any solution? I have a K618i with White LCD when PowerON... |
just gdfs try it works very good |
