04-10-2005, 11:09 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Location: stirling scotland UK Age: 63
Member: 100946 Status: Offline Thanks Meter: 0 | Debrand K700i I am new to using Cruiser. Can anyone guide me to debrand a K700i and P900 and P910i phones. Any help would be welcome. Cheers Coolshak |
04-10-2005, 11:26 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | To debrand a P910i please read this post The way to debrand a P900 is exactly the same, but use the files found here. You might also need to upgrade the Bluetooth in the P900, to do this when you're attached to the PDA part of the phone, click the Flash ARM button and select the bluetooth image from here For the K700i, the manual lists this process if you were to read it (hehe, sorry, couldn't resists) but I'll copy it here for you: Go to the Primary Page of the Control Window. Turn the phone off and attach it to the cable (select "Attach To Phone"). If using auto-detect phone type (the default) be sure Cruiser has correctly identified your phone type. If not, detach the phone, remove and insert the battery and then manually select your phone type from the menu. If necessary, select the Locks tab and press "Unlock RSA". Then reattach the phone. Select your desired language and the desired filesystem (languages are stored in the filesystem image). Be sure to match the correct firmware with the correct filesystem. Select the Flash tab, press "Flash ARM" and select the Firmware image to flash to the phone, Cruiser will then flash the Firmware to the phone. Select the File System tab, press "Write Raw FS" and then select the FileSystem image. Cruiser will then flash the FileSystem to the phone. Select the "Customize FS" option, then flash the correct cusomisation file for the type of phone you're flashing. If you forget to do this step when you power the phone on you will recieve the message "Configuration Error..." on the display. Select "Shutdown FS" and detach the cable. Note: This procedure will erase all user data. Latest K700i files are here Hope this helps you, contact me on ICQ/MSN if you need anymore help. |
debrand k700i | kostask7 | Sony Ericsson | 3 | 06-24-2006 23:29 |
How To Debrand K700i | afrodizzy | Cruiser Suite | 1 | 12-16-2005 18:25 |
Debranding K700i issue | Inovator | SonyEricsson (USB-Smart) | 5 | 11-18-2005 16:57 |
Debranding K700i | stevier | SonyEricsson (USB-Smart) | 9 | 09-07-2005 21:38 |
what is correct method to debrand k700i? | ajh927 | TOTAL MultiServer | 4 | 11-24-2004 12:38 |
