06-24-2005, 20:20 | #1 (permalink) |
Freak Poster Join Date: Dec 2003
Member: 47438 Status: Offline Thanks Meter: 0 | @Lead: plans for supporting DCU-60 USB cable direct? Cheerio, IL |
06-24-2005, 20:54 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | I am not going to implement support for DCU-60. As far as I know, other solutions (server-based) implemented only flashing via DCU-60. It is relatively simple, but it requires an EMMA smartcard attached to the PC. Btw, the communication via DCU-60 is carried out by EROM, so if the EROM is damaged, you can't repair the phone via DCU-60. DCU-60 poses a significant limitation of what can be done with the phone. |
06-24-2005, 21:17 | #3 (permalink) |
Member: 47438 Status: Offline Thanks Meter: 0 | Thanks for the explanation. I didn't know that there are limitations. And yes, you're right: solutions supporting DCU-60 are server-based (and it now also makes sense to me that in those server-based solutions, there is a limit of concurrent connected clients. Obviously, their EMMA-access only allows a certain number of connections at the same time ) Cheerio, IL |
